1973 220D - what kind of oil? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-21-2013, 11:22 AM Thread Starter
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D, 1988 300SEL, 1991 300TE
Quoted: 2 Post(s)
The original owners manual (which I still have) says to use 20w50 or 10w40.
I do not live in a particularly hot area (San Francisco Bay area). My mechanic, a MB factory authorized service center, says they use 5-40.
I've looked on the web to see that some folks actually recommend 5-40 for engines with over 100k because it gives more protection (but they might be comparing it to 10-30). As I read more about this it appears that the 5 (the first number) is less important because it's only when cold and the second number - 40 is what's most important and that matches the manual.
I have no opinion except that I want my car to last forever. What does the web think?
Thanks,
Frank
frankflynn is offline
post #2 of 8 (permalink) Old 08-21-2013, 03:10 PM
Date registered: Aug 2009
Quoted: 66 Post(s)
A 15W40 diesel rated oil seems to be the standard with some using 20W50.
Rotella or the Chevron Delo lines are probably the most recommended. I use Delo400 15W40 in all my Benz.
Mike D is offline
post #3 of 8 (permalink) Old 08-21-2013, 03:12 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Nothing lasts forever. The OM615 was designed to be overhauled after it wore out.
The upper number is indeed the most important. 5W-40 and 10W-40 oils can be used all year in all climates (although in very cold climates 5W-40 is advisable). 20W-50 and 15W-40 is for summer or for warmer climates. Make sure the oil is diesel rated (API C rated). And read all the oil threads ;-)
Govert70227 is offline
post #4 of 8 (permalink) Old 08-21-2013, 04:56 PM Thread Starter
frankflynn's Avatar
Quoted: 2 Post(s)
I've looked at local stores and the oil my mechanic recommends is Diesel (even turbo charged truck diesel) rated. Curiously it's as hard to find as the 20w50.
I will read the oil threads - I have heard that you should be consistent and add the same oil that is already in there. That makes sense.
Thanks for your thoughts.
post #5 of 8 (permalink) Old 08-21-2013, 05:43 PM
Quoted: 66 Post(s)
Pep Boys, O'Relly's, Autozone, Walmart, they all carry the diesel oil brands I mentioned especially with the number of diesel powered trucks on the road. Truck stops have those brands.
Mike D is offline
post #6 of 8 (permalink) Old 08-21-2013, 07:29 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
wall mart is the best place for that , use 15 / 40 shell rotella T .
agillot is offline
post #7 of 8 (permalink) Old 08-21-2013, 09:40 PM Thread Starter
frankflynn's Avatar
Quoted: 2 Post(s)
Wallmart did not have Mobil 1 5w40 - at least the one near me, loads of other weights. O'Rielly's neither, they at least had it but only in the BIG bottle.
post #8 of 8 (permalink) Old 09-07-2013, 05:13 PM
redghost's Avatar
Date registered: Oct 2012
Vehicle: 1972 220 D, 1974 450SL, 1995 E300D 2002 S430, 1976 300D, 1986 SDL, 1982 SD
Quoted: 292 Post(s)
Use a real diesel oil and do not be swayed by weights. You need the ZDDP to be high enough to protect your engine or it will die.
I am up in Seattle and use Mobil 1 15-50 in my 72 220D. The car runs much better than it did on dino oil. Much quieter and much stronger. You may have build up of sludge that is slowly killing the engine. You will of course have changed oil in the past 5000 miles, so there is no need to worry about mixing, when you change the oil again. Just give it a fresh filter and oil, then keep an eye for the detergents in the oil to have cleaned the crud out of the engine. It will take about 10k miles to fully work, but you will be very happy you did.
Clay
74 450SL - Froggy
'02 s320 - Victor
'86 300SDL - Polei
'82 300SD - Allen
Retired cars
'76 300D - Voldemort
'95 E300D - Cleo
'72 220D - Gump
'87 300SDL - POS SDL
92 300SE - #1 boys ride
redghost is offline
