W114 stretched chain - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 08-17-2013, 07:20 PM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
So,
i was adjusting the valves from 0.007 to 0.008 today and had a chance to find the marks for the timing chain.
this thing is not aligned.
how bad is this and could this be causing my "knocking\pinging"?
here is a video of the chain when cylinder 1 is tdc.
W114 timing chain mark - YouTube
kavadarci is offline
post #2 of 10 (permalink) Old 08-18-2013, 05:26 AM
Date registered: Aug 2009
Quoted: 60 Post(s)
It's been a while since I worked on a M130 but that D.S. chain guide doesn't look "right". Anybody else got a M130 they can take a look at to confirm?
You did only rotate the engine clock-wise when you adjusted the valves, correct?
Mike D is online now
post #3 of 10 (permalink) Old 08-18-2013, 06:08 AM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Correct
Nothing but clockwise
post #4 of 10 (permalink) Old 08-18-2013, 07:17 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Normally you would put the camshaft on its mark and then look at the position of the crankshaft. The chain should not be slack if the engine has been turned over clockwise.
Govert70227 is offline
post #5 of 10 (permalink) Old 08-18-2013, 07:18 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 488 Post(s)
by tdc do you mean the crank mark is on "0"?
there are offset woodruff keys that will take back up to 5 deg of chain stretch.
the right side chain where you wiggle it should be tight as that it the way the engine turns and pulls the chain. are u sure you are turning crank bold clockwise?
i think you turned engine wrong direction
rumb is online now
post #6 of 10 (permalink) Old 08-18-2013, 08:28 AM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Looking at the engine directly from the front to the right
post #7 of 10 (permalink) Old 08-18-2013, 10:19 AM
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
So I checked mine and the timing chain along that rail is tight. Moves left and right maybe 1/8" Check out the pics. Theses were shot with the iphone looking into the oil filler cap.
I think you may have found the source of your noise my friend.
ID:	533456   Click image for larger version
Luna Gaudi's 72 250 is offline
post #8 of 10 (permalink) Old 08-18-2013, 10:21 AM
rumb's Avatar
Quoted: 488 Post(s)
as govert said, line up cam marks and then look at crank to see degrees of stretch.
not sure your last post, but yes, standing in front of engine turn clockwise.
rumb is online now
post #9 of 10 (permalink) Old 08-18-2013, 10:26 AM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
So my question is if the chain is trenches do I need to take the engine out to replace?
post #10 of 10 (permalink) Old 08-18-2013, 10:39 AM
rumb's Avatar
Quoted: 488 Post(s)
no, it can be threaded on. the 5 deg cam key will correct 10 deg at the crank.
rumb is online now
