mercedes w115 black smoke - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 08-04-2013, 04:57 PM Thread Starter
Date registered: Jun 2010
hello.. i have 1975 Mercedes w115 with petrol engine 2000 cc when the car is in idling there is a black smoke on the exhaust and the car consume a lot of fuel . i want the advice for this problem please.
mesh3el is offline
post #2 of 11 (permalink) Old 08-04-2013, 05:11 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 488 Post(s)
Please complete your user profile with your location and car info.
How many miles on the car?
Black smoke usually means your rings are gone, or severely gone valve guides.
Do a wet and dry compression test will tell you what you need to know.
rumb is offline
post #3 of 11 (permalink) Old 08-04-2013, 05:33 PM Thread Starter
i am from Egypt and my car have 78000 miles
mesh3el is offline
post #4 of 11 (permalink) Old 08-04-2013, 05:37 PM Thread Starter
i thought that black smoke causing due to an problem in a carburetor
mesh3el is offline
post #5 of 11 (permalink) Old 08-04-2013, 07:20 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
It might be that your carb is set to be too rich at idle. However, you would know this by smelling the exhaust at idle. If too rich, you'll smell unburnt petrol. If it's oil causing the smoke (bad valve guides or rings), the smell will be from a worn out engine.
Grubeguy is offline
post #6 of 11 (permalink) Old 08-05-2013, 06:22 AM Thread Starter
thank you for advice
mesh3el is offline
post #7 of 11 (permalink) Old 08-05-2013, 07:25 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
stromberg carb
primarily check carburettor needle valve could be worn out and overfilling the carb .this will result in black smoke sluggish running.
ad
adler is offline
post #8 of 11 (permalink) Old 08-05-2013, 10:32 AM
Date registered: Jul 2012
Vehicle: 1967 250S, twin Weber carbs, automatic trans, power windows, A/C, R134a conversion
In general...
Black smoke = Fuel mixture is too rich
Blue smoke = Engine is burning oil
There can be a multitude of reasons for each condition. You will have to check each during your diagnosis
Kitaka is offline
post #9 of 11 (permalink) Old 08-12-2013, 02:48 PM Thread Starter
at first thank you KITAKA but i want to know how to set fuel mixture in the carburetor that there is a nut on the button of the carburetor is that responsible for air fuel ratio.
thanks
mesh3el is offline
post #10 of 11 (permalink) Old 08-12-2013, 05:14 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the chocke valve could be stuck on , there is a small diaphragm at the fuel return valve , if it leaks , you will be sucking gas into intake [ vacuum line under carb .]
agillot is offline
