1971 280SE: motor oil ? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 08-01-2013, 01:36 PM Thread Starter
zappo's Avatar
Date registered: Sep 2012
Any particular type of motor oil (both grade, designation and brand) I should be using for my '71 280SE ?
thanks,
Benny.
zappo is offline
post #2 of 13 (permalink) Old 08-01-2013, 05:37 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 488 Post(s)
You will prob get different answers but I use Rotella 10-30. It has good additives for older engines.
rumb is online now
post #3 of 13 (permalink) Old 08-01-2013, 06:38 PM
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Same here Rotella 15W 40
kavadarci is offline
post #4 of 13 (permalink) Old 08-01-2013, 07:18 PM
Matvh's Avatar
Date registered: Jan 2011
Vehicle: 1969 280 SE Convertible
Oil for 69 280SE
Been using Castrol GTX 20W50 for a while
Castrol has been an approved oil for MBZ many years
Matvh is offline
post #5 of 13 (permalink) Old 08-02-2013, 05:40 AM
Date registered: Apr 2012
My .02 is...
Any Diesel engine oil, in a weight suitable for your climate.
Palolo is offline
post #6 of 13 (permalink) Old 08-05-2013, 07:33 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
20/50 any major brands .
agillot is offline
post #7 of 13 (permalink) Old 08-05-2013, 03:31 PM
Date registered: Jul 2013
Vehicle: 1973 280se
So it seems like the colder climate guys stick to 10-15/30 while the more "normal" climate (southern california here) people are going with a 20w/50. I'm going to change the oil for the first time on my w108 4.5 too. I appreciate the question and input. One more thing...does anyone go with synthetic for these cars?
alee8677 is offline
post #8 of 13 (permalink) Old 08-05-2013, 04:21 PM
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
No
Synthetic is too thin and you will have leaks
Unless your engine is rebuild but most will not recommend
post #9 of 13 (permalink) Old 08-05-2013, 04:23 PM
Vehicle: 1973 280se
Oh ok gotcha. Thanks for the input.
alee8677 is offline
post #10 of 13 (permalink) Old 08-06-2013, 09:40 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Do some research on synthetic. It does not cause leaks. In fact in many cases it stops leaks. If your car already had leaks, then they need to be attended to. Synthetic causing leaks is an issue that was an issue twenty to thirty years ago when they were first starting to get widespread use. That is old news since synthetics have additives that swell the seals just like dino oils. I have used synthetics in every car below except the 240D and no new leaks.
Len
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 207,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 9700 miles
sokoloff is offline
