Gear changing linkage - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-01-2013, 09:43 AM Thread Starter
Date registered: Dec 2012
Vehicle: 1978 230
78 230, w123. There is a rod that moves fore and aft when you move the gear change lever. It connects to the trans to change the gear. Mine became disconnected and all I see is the rod and the metal part that the rod should connect to. Sorry I don't know the exact terminology. There must be some sort of Teflon or rubber part that connects the rod to the other part. Can any one help me out with some info about that? I cant find any pictures or part numbers or anything else, though it has to be a replace-able thing. I had to rig it last night with picture hanging wire in order to get home and I don't consider that much of a permanent fix.
Justin
beyeker is offline
post #2 of 2 (permalink) Old 08-02-2013, 01:55 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
The part number is A1159920310. Best to change them both (at the transmission and at the gear change lever). They are not expensive:
Your Parts Search Returned 1 Part(s)
Govert70227 is offline
