Heater core removal - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-20-2013, 02:09 AM Thread Starter
Pizing82's Avatar
Date registered: Jun 2013
Heater core removal
Hi guys, I need to repair, replace my heater core in my w109 300sel. Looks challenging and I'm looking for some advice of where to start, are there any shortcuts or tips from ppl who have done this before?
Is there anything else I should consider fixing or looking at doing at the same time of this repair?
Pizing82 is offline
post #2 of 7 (permalink) Old 07-21-2013, 07:12 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
I've done this job, only because the mechanic at the time wouldn't take the 32 hours away from other customers to do it. It's a bitch. Recommend you do a general search in the forum for the same topic - I've seen a couple threads with a lot of good info and even some step by steps.
In short, the easiest way to get at the heater core is to take out the front seats, and everything (yes, everything) from the dash, except for the dash itself. The radio, the wood, the instrument cluster, glove box, speedo cable, etc etc.
If you're going to do the job, I'd recommend having an assistant who will take careful notes of what came from where and how it goes back. Some stuff will be obvious.
I recommend you inspect and replace as necessary the heater control levers. The parts are available from a couple vendors that are still in business. Also, if you're replacing the core, I'd consider replacing the blower motor as well (unless you can say with certainty that the thing is good).
In lieu of replacing the core with a new one, I'd recommend taking it to a radiator shop and having them repair the coils as necessary. A complete radiator rebuild will cost about $250, but a heater core would be much less, and thus more cost effective than buying a new replacement.
This job isn't "un-dooable," but it does take patience and time. It definately wasn't a weekend job for me
Grubeguy is offline
post #3 of 7 (permalink) Old 07-21-2013, 08:12 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
The only thing to consider here is whether you can afford a good therapist or will you only consult with Mr Jasper A. Daniel.
flyboyike is offline
post #4 of 7 (permalink) Old 07-22-2013, 04:25 AM
Grubeguy's Avatar
Quoted: 102 Post(s)
I swear, if/when I ever get to my 300's restoration, I'm going to pull the heater core out and put it in the enginy bay where it's easy to get to...
Grubeguy is offline
post #5 of 7 (permalink) Old 07-22-2013, 05:06 AM Thread Starter
Pizing82's Avatar
Anyone ever fitted a ceramic core to fix the problem once and for all.
Pizing82 is offline
post #6 of 7 (permalink) Old 07-22-2013, 07:50 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
if you dont want to evicerate the car , and just want heat , you could install a self contain heater unit at passenger side , and connect to 12 v and 2 heater hoses . it is about the size of a small electric heater for a room .
agillot is offline
post #7 of 7 (permalink) Old 07-23-2013, 10:21 AM
flyboyike's Avatar
Quoted: 69 Post(s)
I presume our friend will only drive the car on nice days, so I'm almost thinking he can just crimp off the heater hoses and not have heat at all, and be none the worse for it.
