M130 W114 valve clearance - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-14-2013, 05:55 PM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
I set my valve clearance to 0.003 intake and 0.007 exhaust as per Haynes manual.
I just noticed on a plate in the engine bay it says 0.003 intake and 0.008 for the exhaust
My question is how big of a problem is this and should I change to 0.008 or leave it as is?
Thank you
kavadarci is offline
post #2 of 4 (permalink) Old 07-14-2013, 07:42 PM
Date registered: Aug 2009
Quoted: 49 Post(s)
Not a big deal. Setting at the .007" is fine as long as it is a "loose" .007", .008" is for the original, pristine engine tolerances. I guarantee you have more than .001" of wear between the cam and valve stem surfaces.
Mike D is offline
post #3 of 4 (permalink) Old 07-14-2013, 09:34 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Haynes is not very dependable ,just a handy manual without any detailed specs .
I have had best results with .10 mm In and .20 mm EX and timing advanced to 11"BTDC .Compensates for chain wear.
adler is offline
post #4 of 4 (permalink) Old 07-15-2013, 05:06 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
no , you are fine , 7 th for ex , sometime on a engine that wear intake valve , i put 5 th on intakes .
agillot is offline
