W114 trunk insulation - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 07-14-2013, 09:58 AM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Hi,
I have just finished installing b-quiet sound deadening and on top b-quiet hliner
Combination of both are used to reduce heat, noise and vibration.
Trunk feels solid now and it should help when I install sub later
Before:
B-quiet extreme
B-quiet hliner
kavadarci is offline
post #2 of 12 (permalink) Old 07-19-2013, 09:42 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
is the reflective side of insulator on the outside area or inside ?
adler is online now
post #3 of 12 (permalink) Old 07-20-2013, 06:07 AM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Outside
The other side has the adhesive
post #4 of 12 (permalink) Old 07-20-2013, 10:08 AM
Date registered: Aug 2009
Quoted: 73 Post(s)
The h-liner is a BAD idea! The problem with the foam insulators is that they will absorb and store moisture. While this isn't a problem for engine compartment/firewall applications due to them being vented to the outside air, it IS a problem in a sealed area such as the trunk. They'll mildew and begin to stink.
Use one of the thinner "bubble" type pads for trunk and interior applications. These are sealed cells and don't collect moisture.
Mike D is online now
post #5 of 12 (permalink) Old 07-20-2013, 03:03 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Agreed buy that is why I put the b-quiet extreme before adding the hliner so the moisture if collected doesn't stay on the metal
post #6 of 12 (permalink) Old 07-20-2013, 04:35 PM
Quoted: 73 Post(s)
It won't prevent the "stank".
post #7 of 12 (permalink) Old 07-20-2013, 06:01 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
If it does what you say it will do it is easily removable
post #8 of 12 (permalink) Old 07-20-2013, 08:17 PM
Quoted: 73 Post(s)
Sigh, "an ounce of prevention...."
post #9 of 12 (permalink) Old 07-21-2013, 07:19 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 107 Post(s)
And a dilute bleach/water mix will take care of stank, if it happens.
Where would the water come from? If the drain gunnels leak, the water will go to the floor of the trunk and collect in the low spots, not in the foam. Are we talking condensation here? Normal humidity?
Grubeguy is offline
post #10 of 12 (permalink) Old 07-21-2013, 08:28 AM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
In my opinion it should be absolutely fine
I have zero moisture in the trunk it is dry as a bone with no leaks or rust
