Vacuum diagram 1972 W108 280SEL 4.5 - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 07-10-2013, 04:38 PM Thread Starter
Date registered: Feb 2012
Vehicle: 2006 C230 Sprots V6, 1972 280 SEL 4.5
Can anyone direct me to a vacuum diagram for a 1972 W108 280SEL 4.5? I have several broken vacuum hoses which leads to nowhere. One in particular is a vacuum hose that runs along the top right side of the engine. Another is behind the battery compartment and two along the firewall. If anyone can provide me a photo of their W108 vacuum hose locations (door and emission) it will help me out considerably. Unfortunately for me, I seem to be the lone W108 owner in my area.
wfd1 is offline
post #2 of 10 (permalink) Old 07-10-2013, 10:47 PM Thread Starter
Here are some photos. Where do these vacuum lines attach to and what are their functions?
wfd1 is offline
post #3 of 10 (permalink) Old 07-11-2013, 07:05 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Picture one is of a vacuum check valve. It heads into the driver' side inner fender, where the vacuum reservoir resides. I'd wager your door locks don't lock with vacuum, nor does your gas tank fill door. It's not required for the engine to run correctly, but it effects some convenience items.
The others (and I'm about 90% sure on this) are to the changeover valve circuit (changing air/fuel ratios once the engine is warm).
I'd LOVE to see a vacuum diagram too - I've never run across one and I've got a couple good manuals for the thing.
Grubeguy is offline
post #4 of 10 (permalink) Old 07-11-2013, 08:23 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the yellow two way valve is ignition retard cancel when a/c on , and also when engine temp is at 212 d . it connects to the trottle body , and the other to the distributor retard .the other yellow line should connect at a vacuum pipe at rear of intake , it should have a Y connector , and also to the vacuum tank under right fender .
agillot is offline
post #5 of 10 (permalink) Old 07-11-2013, 02:13 PM Thread Starter
I suspected pic 1 was for the door locks. What threw me off was that the check valve did not have a Y connector. I do have a diagram for that but would appreciate if anyone has pictures to show me.
wfd1 is offline
post #6 of 10 (permalink) Old 07-11-2013, 02:17 PM Thread Starter
That helps me a lot, thank you. I also noticed a vacuum hose running along the engine between the right valve cover and intake manifold. Any suggestion where this connects to? If you have any photos please post. Thank you.
wfd1 is offline
post #7 of 10 (permalink) Old 07-11-2013, 05:32 PM
Premium Member
Quoted: 59 Post(s)
Premium Member
it goes from the electr vacuum valve that you show to the retard box on distributor
agillot is offline
post #8 of 10 (permalink) Old 07-12-2013, 08:45 AM Thread Starter
Okay great. Thank you for your help. Do you know if that vacuum line has anything to do with idling? My W108 seems to never go down on idle. It stays at a constant as if it is constantly warming up.
wfd1 is offline
post #9 of 10 (permalink) Old 07-14-2013, 08:32 AM Thread Starter
Okay, I traced the hoses to t retard and it seems as if the previous owner bypassed the vacuum device. The retard box from the distributor is connected directly to the throttle body. Should there have been a Y connector from the distributor retard o throttle body?
wfd1 is offline
post #10 of 10 (permalink) Old 11-30-2014, 12:04 AM
Date registered: Mar 2014
Vehicle: 2006 CLS 500, 1972 280 SEL
Final results?
Were you ever able to figure out your vacuum system? I'm looking at a similar problem with my W108 280 SEL, plus the wiper fluid box is missing.
Was hoping for some pictures of a correctly set up vacuum system...Anyone got one of these technical marvels?
peterjs72 is offline
