280SE fuel injector struggles... - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-09-2013, 09:52 AM Thread Starter
Date registered: Jun 2011
Vehicle: 1971 280SE
Hello all,
I had a quick question for those of you that are more handy with a wrench than I am (which, I am guessing, is the vast majority of the people on this forum):
I have a 71 280SE m130 and I was wondering how you unscrew the pipes that connect to the engines fuel injectors? I have a 17mm wrench that fits but there's no clearance to twist the nuts that are holding the pipes in... Do I need a special tool? Am I just missing something obvious?
There should be a picture attached to explain more clearly where I'm referencing.
Langerboo is offline
post #2 of 3 (permalink) Old 07-09-2013, 04:00 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 1968 250S, 1991 300se, 1998 SL500, 2x 1977 450SEL 6.9. Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 405 Post(s)
I would try a crows foot wrench. You will need to get one wrench on the injector and another on the pipe connector. Sometimes I just bend wrenches with a torch to fit.
rumb is online now
post #3 of 3 (permalink) Old 07-09-2013, 08:28 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
no , as long as injector is tight in head , and does not spin around . a normal or bent wrench will do it .num 1 is the hardest .
agillot is offline
