adjust timing 5 degrees? 220d wont start.. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-05-2013, 09:50 PM Thread Starter
Date registered: Aug 2012
Post adjust timing 5 degrees? 220d wont start..
pretty big overhaul on this om615 and now I cant get it to start. is emitting exhaust out of intake manifold when cranking, timing is about 5 degrees ATDC when camshaft marks are aligned. Fuel seems to be getting out of the tailpipe so I think all other systems are good, how do I adjust the timing so little? Or do you think it is a different problem? thanks
220biodeezy is offline
post #2 of 3 (permalink) Old 07-06-2013, 05:22 AM
Date registered: Aug 2009
Quoted: 49 Post(s)
Ummm, you set the fuel timing at 24 BTDC using the "drip" method. There is a mark (or was) on the dampener indicating the stock position.
Mike D is offline
post #3 of 3 (permalink) Old 07-06-2013, 12:05 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
i wonder if the front damper on crankshaft is 180 out , remove valve cover , put engine at tdc of number 1 cyl , push by hand a valve on numb 1 cyl , it should go down a small amount and hit the top of piston , if it goes all away down , you are 180 out .
agillot is offline
