W114 power steering problem - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-13-2013, 05:44 AM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Hi
I drove the car for short distance today and when parking strange noise was coming from the engine compartment and the steering wheel felt weird.
Opened the hood and there were bubbles coming out of the power steering reservoir.
I slowly opened the screw at the top and oil started to come out of it. The oil was all with bibles it had a lot of air in like it was mixed a lot.
What might be causing this type of issue and what should I check?
Thank you
kavadarci is offline
post #2 of 5 (permalink) Old 06-13-2013, 10:41 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 115 Post(s)
Start with checking the bleed valve on the steering box. You should be able to put a tube over the bleed valve, open it, and when engine running fluid should pump out the bleed valve (which you can send back into the reservoir). To bleed the system I think you have the car running and slowly turn all the way to the left the right and see if air comes through the tube. If it does, repeat. If it doesn't good. You have a bunch of air somewhere getting in.
Scoot is offline
post #3 of 5 (permalink) Old 06-13-2013, 11:43 AM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Thank you
I will try that
I did replace the hoses while back because they were cracked and leaking and I have been driving around but all of sudden I have air. Strange
I have no leaks on the ground at all not a single drop
I will bleed the pump and advise
Thank you
post #4 of 5 (permalink) Old 06-13-2013, 03:21 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
Look at the video first
The reason why it is "boiling" is that the new hose got soft, bent and blocked the fluid flow.
I guess I need different type of hose. This problem is solved
Thank you
post #5 of 5 (permalink) Old 06-13-2013, 04:18 PM
Date registered: Aug 2009
Quoted: 53 Post(s)
I see the problem. It's a matter of color clash. The red engine, the purple air filters and the green rag. It ain't bubbling. it's throwing up!
Mike D is offline
