w108 new owner - Page 3 - Mercedes-Benz Forum
post #21 of 30 (permalink) Old 03-17-2014, 07:43 PM Thread Starter
BenzSid124's Avatar
Date registered: Jun 2012
Vehicle: 1994 E320, 1990 300CE Coupe, 1971 280S
Here are some more pics. I also ran the car and kicked in the AC, it blows cold still! Very neat for sure. Here are some more pics...
Sid
Mercedes-Benz Master Guild Certified Technician
AMG Performance Specialist
Gas/Diesel Certified
Hybrid Certified
HVAC Certified
1994 E320 Sedan
1990 300CE Coupe
1971 280S Sedan
1970 280S Sedan Japan Import
ID:	843066   Click image for larger version
ID:	843074   Click image for larger version
ID:	843082   Click image for larger version
-Sid
Mercedes-Benz Master Certified Technician
Hybrid Certified
HVAC Certified
1994 E320 Sedan
1990 300CE Coupe
1971 280S
BenzSid124 is offline
post #22 of 30 (permalink) Old 03-18-2014, 12:45 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Thanks for pics of A/C and controls,where does the freon piping from the compressor run ,under or from inside the car?
Ad
adler is offline
post #23 of 30 (permalink) Old 03-18-2014, 07:29 PM Thread Starter
BenzSid124's Avatar
Suction line goes down through the passenger side fender and runs along to frame rail into the trunk. The pressure line exots on the drivers side of the trunk and also goes up the frame rail to the engine bay and runs up and over the condenser to the dryer. Pretty simple setup. Im looking into a price for the whole system still.
Sid
Mercedes Benz Master Guild Certified Technician
Hybrid Certified
HVAC Certified
1994 E320 Sedan
1990 300CE Coupe
1972 280S Sedan
-Sid
Hybrid Certified
HVAC Certified
1994 E320 Sedan
1990 300CE Coupe
1971 280S
post #24 of 30 (permalink) Old 03-18-2014, 10:40 PM
Quoted: 59 Post(s)
Interesting layout for the A/C pipes,and a long route!
adler is offline
post #25 of 30 (permalink) Old 03-23-2014, 08:14 PM Thread Starter
BenzSid124's Avatar
I have started dismantling the car, got quite a bit done already but I have about 20 more hours until I'm done.
Since I have been getting so many inquires about things my message box is out of control.
I'd like for anyone who is requesting a part or info to email me at jasonsid1985@gmail.com
I will be responding from there since it will be easier. Please be sure to give me your zip code and items interested in. Thanks!
Sid
Hybrid Certified
HVAC Certified
1994 E320 Sedan
1990 300CE Coupe
1971 280S Sedan
-Sid
Hybrid Certified
HVAC Certified
1994 E320 Sedan
1990 300CE Coupe
1971 280S
post #26 of 30 (permalink) Old 03-31-2014, 08:46 PM Thread Starter
BenzSid124's Avatar
Well the car is finally in 1,000,000,000 pieces. I have removed EVERYTHING from the car that is still in usable condition. The only part of the car that I have not touched is the running gear and suspension. The steering gear box will most likely come out before I junk the car. I am still bouncing around the idea of keeping the rear end and parts from the front end. As of now I am out of room for storage. The car is going to sit on a trailer hidden in the back yard for a month or two just incase someone needs something off of it. I would like to see as much of this car used as possible.
All that being said I will list below all the good parts I have taken off that I am willing to part with. If it's not listed, I probably still removed it but haven't thought about selling it yet. Please feel free to still ask if I can part with it.
Again with part requests, pictures, or questions please email jasonsid1985@gmail.com
I have learned a lot about the w108 as I took it apart. I have spent 8 years working at a dealer on cars from 2000 and up. It's a whole new world going to something this old. Well made and solid!
Spread the word! I need to move this stuff so I have room to work on my own w108 now!
Exterior:
---All trim items(fresh air inlet, front and rear windshield, rocker panels, centerbody, doors, and windows)
---All exterior door handles
---Front windshield(no crackes or chips)
---Rear windshield(no cracks or chips)
---All 1/4 windows(no chips or cracks(fronts have mechanisms on them))
---All door windows(no chips or cracks)
Doors
---Window cranks
---Strikers, Latches, Rods
---Window guides
---Window regulators(hand crank style(all work))
---Door panels
---Door panel trim items
---Door pulls
---Ashtrays(for rear)
Electronics
---Windshield wiper motor w/linkages
---Power window motor w/wiring(added on)
---Instrument cluster(in KPH)
---Front courtesy light
---Rear courtesy light
---Reading lights(C-pillars)
---Cigar lighter
---Hazard switch(pull style)
---Kickdown switch
---Becker radio(undecided on sale of this item)
Interior
---Front seats(good condition, no tears, minor fading)
---Rear seat bench(bottom and back(good condition, not tears, minor fading))
---Windshield trim(inside window surround)
---B pillars(material coming off)
---Center console(with carpet)
---Glovebox(with wood)
---Ashtray(with wood)
---AC control bezel
---AC vents(driver and passenger)
---Center speaker cover
---Steering wheel(has cracks)
---Steering wheel pad(minor cracking)
Miscellaneous
---Steering column(complete)
---Vehicle jack
---Rear taillight assemblies
---Ebrake lever with cable
---Ebrake cables(upon request)
---Throttle linkage assembly(piece mounted to firewall)
---Gas pedal
---Speedometer cable
---Gear change lever(column mount)
---Washer pump(includes lines, pedal pump, nozzle)
Air Conditioning
---Nippondenso trunk mounted air conditioning unit(includes all wiring, unit controls, regulators, relays, condensor(ignition), coil(ignition, capacitors(ignition), vents, drain tubes, and modules.
***This is a very well put together system. There are several pieces and components to install for proper operation. I recommend having a professional service center install this equipment. I can supply pictures of all mounting positions, components, and location of parts and wiring. I will also do my best to assist with questions regarding the installation of the system. I have yet to find ANY information on this system on the internet. I do not know of the value. I will accept offers on it. I am not trying to make a bunch of money off of it, I would rather see it used.***
I have pictures of almost all of the items listed above and will be happy to send them.
Sold items: all seat belts, front carpets, rear headrests
Again please email jasonsid1985@gmail.com
Thanks!
-Sid
Hybrid Certified
HVAC Certified
1994 E320 Sedan
1990 300CE Coupe
1971 280S
post #27 of 30 (permalink) Old 03-18-2015, 07:12 PM Thread Starter
BenzSid124's Avatar
Well I finally got this old girl up and running! I actually used it in my wedding in October last year. It still needs some carb work but after swapping the engine and transmission out of the Japan 108 I found, it's running. I also had to redo the entire brake system. New calipers, rotors, booster, master cylinder, and wheel bearings. Runs and drives pretty good. Got it cleaned up a bit and it was wedding worthy. The car sat in a barn for 12 years before I got it, 2 years later it was back on the road! Check it out...
ID:	1364130   Click image for larger version
ID:	1364138   Click image for larger version
ID:	1364154   Click image for larger version
ID:	1364162   Click image for larger version
ID:	1364178   Click image for larger version
speed9644 likes this.
-Sid
Hybrid Certified
HVAC Certified
1994 E320 Sedan
1990 300CE Coupe
1971 280S
post #28 of 30 (permalink) Old 03-18-2015, 07:13 PM Thread Starter
BenzSid124's Avatar
Oh! I also added the Japan spec mirror on the passenger fender!
MCMLXIX likes this.
-Sid
Hybrid Certified
HVAC Certified
1994 E320 Sedan
1990 300CE Coupe
1971 280S
post #29 of 30 (permalink) Old 03-18-2015, 07:46 PM
MCMLXIX's Avatar
Date registered: Dec 2013
Vehicle: 2006 S65 AMG V12 Biturbo
Quoted: 87 Post(s)
Car looks great. Love the JDM mirror.
Rich
2006 S65 AMG 1 of 427 in North America {For Sale}
1986 560SEL {FOR SALE}
MCMLXIX is offline
post #30 of 30 (permalink) Old 03-19-2015, 06:56 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 444 Post(s)
Great job, car looks nice. next step strip and repaint the air cleaner.
rumb is offline
