280SEL - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 05-25-2013, 04:16 PM Thread Starter
Date registered: Aug 2012
Vehicle: 1970 280SEL
280SEL
I have a radio question, I have a stock Becker Europa radio. My question is what ohm rating should that radio require? It's AM FM with only one speaker in the dash. I replaced the original with a 4 ohm speaker and it works but volume is low with it turned all the way up. Any ideas?
1970 Mercedes Benz 280SEL
VIN 10801912050616
1967 Mercedes 250SE
Parts Car
jman1151 is offline
post #2 of 9 (permalink) Old 05-25-2013, 05:41 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 480 Post(s)
Did it work before? Your radio probably needs rebuilt.
rumb is online now
post #3 of 9 (permalink) Old 05-29-2013, 07:25 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
These period radios have a low power amp ,most work best with small 4 Ohm speakers ,a speaker with a massive magnet assembly requires massive power too so is mismatched here though may be of correct impedance;other than that the output transistors are faulty in the unit
adler is offline
post #4 of 9 (permalink) Old 05-30-2013, 05:12 AM Thread Starter
Thanks for the replies, I guess its time to send it off to the Radioman
VIN 10801912050616
1967 Mercedes 250SE
Parts Car
jman1151 is offline
post #5 of 9 (permalink) Old 05-30-2013, 10:52 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
Is the radio the same volume independent of where you have the volume knob? Or does it get from really quiet to quiet? If the volume control works then try an appropriate speaker. Low-power beckers work horribly with modern high-power speakers.
Scoot is offline
post #6 of 9 (permalink) Old 05-30-2013, 11:22 AM Thread Starter
The volume control does work, and I do have a 4"X6" - 4 ohm speaker. On a scale of 0 -10 the volume only reaches maybe a 3 if you understand my analogy.
VIN 10801912050616
1967 Mercedes 250SE
Parts Car
jman1151 is offline
post #7 of 9 (permalink) Old 05-30-2013, 11:25 AM
Scoot's Avatar
Quoted: 121 Post(s)
Do you have another low-power speaker. Sometimes it can also be the speaker... Is this a radio with a separate amplifier? My experience with these radios says that you need a known-good radio to test speakers and known-good speakers to test radios and known-good amplifiers to test radios with separate amplifiers and known-good radios to test amplifiers for radios with separate amplifies. Also, a 4 x 6 4 ohm speaker may still not be an appropriate speaker for this situation.
Scoot is offline
post #8 of 9 (permalink) Old 05-30-2013, 11:26 AM
Scoot's Avatar
Quoted: 121 Post(s)
If you go to scrap yards, get a speaker out of the back doors of an early W124. Or out of a W123, but those are often trashed from the sun.
Scoot is offline
post #9 of 9 (permalink) Old 05-30-2013, 11:31 AM Thread Starter
The radio has no amp. The speaker is just a generic 4 ohm and I have tested it in my truck and it works well.
VIN 10801912050616
1967 Mercedes 250SE
Parts Car
jman1151 is offline
