1970 w114 250 Benz - Page 5 - Mercedes-Benz Forum
post #41 of 70 (permalink) Old 06-06-2013, 07:18 PM Thread Starter
Date registered: May 2013
Vehicle: 1970 250. W114. Sedan. Green
Thanks Harald yep
That's my (equipment) shop, got a "pit" to...
Finally got her running tonight , spit sputtered carried on for 45 minutes, until I made up my mind to sit in seat and hold it at 1/4 throttle for 10 minutes then she evened out but still would die out at idle ( I then changed in line fuel filter)and it ran steady...
CRAZY thing happened as I was toying with the double zeniths,using carb spray and w40 my darn shop rag caught front fan and stopped fan .i quickly shut her down ,but now I have no fan function , i checked fuses they were ok thought I popped a fuse but now I have no frt. fan function. I wonder if I burnt it out?? Or is there a separate fuse for this.?
Is it normal for this fan to run as soon as ignition is on ,as it did.
Scared the heck out of me + one must be very aware of that open fan running while hood is open
Got one rear brake functioning also cant get fluid to bleed from other side
Can't find forums on the carbs as w114's are not listed in choices?
I will look into title info given from jaymayard
One other note as I fired it up tonight she stuck in full throttle momentarily till I nailed it down then found carb linkage came off and small retinue spring fell off
This is like climbing a mountain
Anthonycars is offline
post #42 of 70 (permalink) Old 06-06-2013, 07:23 PM Thread Starter
How bout the vin search as I entered my vin and no match comes up
post #43 of 70 (permalink) Old 06-11-2013, 07:39 PM Thread Starter
Rumb
When you replaced the rear caliper(s) did you have to change the brake line connection into the caliper ,as I do not see a direct fit up , as mine seem to be origional
post #44 of 70 (permalink) Old 06-12-2013, 05:47 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 499 Post(s)
Are you saying the new brake line to the caliper has different size threads? If you had one made, they should be able to make it with the correct size.
Name:	250 rear brakes.gif
rumb is offline
post #45 of 70 (permalink) Old 06-12-2013, 03:18 PM Thread Starter
Thank You for the diagram
my new original replacement caliper has a different location for the existing metal feed line [116 per diagram ] inlet { WOW this must be orig. caliper}ATI brand
After looking at diagram I believe I will need to make/buy a short jumper line which would go from old brake line to new caliper - Yea ? as I have new caliper installed
[ Almost ready to test drive -another day - I think }
Chow
post #46 of 70 (permalink) Old 06-12-2013, 07:34 PM
Date registered: Mar 2011
Vehicle: 1971 250/8 sedan with 80 K miles. Driven only in Summer.
coming back to your carbs Anthony, there is a lot of info. under online resources
http://www.benzworld.org/forums/vint...sources-3.html on page 3 by Grubeguy. including your brake problems ect. Good luck. Harald
Over 75 is offline
post #47 of 70 (permalink) Old 06-13-2013, 03:25 AM
kdjones99's Avatar
Date registered: Jul 2010
Vehicle: 1967 250SE (W108)
Quoted: 4 Post(s)
I had the same problem with the calipers. They make 2 different versions of calipers (for my 67 at least). I kept getting the one with the connection in the wrong spot too. Finally just took my originals in to get rebuilt.
kdjones99 is offline
post #48 of 70 (permalink) Old 06-13-2013, 07:03 PM Thread Starter
Thank Harald, kdjones99
Today I went to NAPA , they ordered rubber jump brake lines for me ,as orig. cal. Are out of production. Gotta wait 3 days now
post #49 of 70 (permalink) Old 06-13-2013, 07:15 PM Thread Starter
Dropped rear diff oil tonight, actually looked golden new, not bad for last service was 12 years ago. Title is still problem , as I must surrender title to get my name on new title, in order to get insurance ,inspection plate etc even if I apply for a lost title
post #50 of 70 (permalink) Old 06-13-2013, 07:25 PM Thread Starter
Jaymayard
If I retitle my benz I have to send in the orig.A title to PADOT , then they keep it
I can't apply for a lost title, as I never had the benz registered, yet.
I can,t even get plates with out surrendering orig. A title signed by the actress.
Unless I keep the car as is , and store it away , Don't want to d this,
Does this make sense
