resistors 280se 1974 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-18-2013, 07:06 PM Thread Starter
Date registered: Sep 2006
Hi
This is part of a previous thread but has a life of its own.
RIGHT I fixed a fuel problem but was having trouble with flooding before the car would start. I have bridged the ceramic resistors to give maximum feed to the coil. and am up and running. What does this show is wrong?? what is the problems i may have if i leave the bridge on ??
Cheers Bryan
bcullen is offline
post #2 of 3 (permalink) Old 05-18-2013, 07:45 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
without a ballast resistor the coil will overheat and burn out .if engine runs in that condition only then coil is defective .
Best would be a Pertronix coil and ignitor and do away with the old ignition and end ignition related issues.
adler is offline
post #3 of 3 (permalink) Old 05-20-2013, 04:21 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
You can also run a wire from the small ternimal on the starter to the + side of the coil. That way the coil will get full voltage only when you are cranking the starter.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
