M-B Special Tools Needed - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-15-2013, 08:21 AM Thread Starter
Date registered: Mar 2013
Vehicle: 1967 Fintail 230S
As I try to get my Fintail in better driving condition, I realize that I need special tools to tackle some of the routine jobs. I am looking to rent or purchase a used valve spring compressor tool for the old L6 engine (M180). Does anyone have this tool available?
Also, I want to remove the pinion nut on the W108 rear end I intend to put under the car. Is it possible to cut slots in the correct size socket to fit that nut? Has anyone done this, or has the correct socket for rent or sale? What's the size of that nut?
I only intend to do these jobs once, so I don't want to invest a lot in these "once in a lifetime" tools. Thanks in advance.
Coolvibes is offline
post #2 of 2 (permalink) Old 05-16-2013, 08:12 AM
Date registered: May 2013
Vehicle: 1961 190SL
Coolvibes,
I'm a newbie and know nothing about MB in general and only a tiny bit about my wife's 190sl. However I've been an amateur mechanic for over 50 years and the solution to your quests should not be too difficult.
I am learning, however, about the quirks of these cars. For example I just found that in order to change the fan belt the engine had to be raised about 1/4" because the harmonic balancer is too close to the front cross member.
A valve spring compressor is a generic, very common tool. Here in California some auto parts stores loan them for a deposit equal to the value of the tool. They are probably abundant on ebay also for less than you would expect to rent one for.
If the nut you wish to remove is large, in the large metric sizes there is often an inch wrench that is very close. Again, I know next to nothing about MB but whenever I've removed a differential pinion nut to replace the seal I've first marked its exact position on the pinion so it can be put back exactly as I found it.
Some have a minimum required torque, often over 200 ft.-lbs. I've made an extender for my 1/2" drive torque wrench that both doubles the torque and adapts on 3/4" drive sockets. If a photo of that would be helpful I'd be glad to send one if you give me an email address to use. Mine is rwaldbaum@aol.com.
I'm not a "purist" and I've found that the alleged need for a "special tool" is often an exaggeration used to discourage people from the do-it-yourself approach.
Ray W
Waldbaum is offline
