W108 power window works at door, not at master - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-02-2013, 10:43 AM Thread Starter
Scoot's Avatar
Date registered: Oct 2002
Quoted: 118 Post(s)
The left rear power window works from the door switch but not from the master switch. The master switch was replaced with a NEW one from MB, and it still doesn't work. I believe the wiring to be correct at the switch. There is power going to the red wire at the switch. I have swapped several other used switches with the same result - front left works, back left doesn't work.
1981 300 D FWIW
Suggestions?
thanks
Scoot is offline
