workshop manual w107 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-29-2013, 12:16 AM Thread Starter
Date registered: Nov 2009
Vehicle: 280sl 4spd manual german import lhd
Hey guys, Im looking after this beautiful 280sl (see prof pic) on behalf of a good friend of mine. Never been into classics, but this ones growing on me. Since pic was taken, she has been machine polished and rims are just back from refurb, this car is immaculate
Anyhow, Im looking for a workshop manual, engine mainly.... can anyone help me? cheeeers
pinnerford is offline
post #2 of 5 (permalink) Old 04-30-2013, 08:14 AM
OldWorldShepherds's Avatar
Date registered: Jan 2012
Vehicle: 1989 560 SL - Signal Red & Palomino; 2011 C-300 - Black on Black 4MATIC
Quoted: 91 Post(s)
Pinneford, check out the 107 section of this forum, and you will find all the info you will likely need, hardcopy manuals are not easy to come by but look in the "Stickied" sections - especially the "Encyclopedia Germanica" and you will see links for further info including a source for the manuals loaded onto a CD.
That said, 99% of what you will likely need has probably been covered on the forum.
Happy Motoring!!
1989 Mercedes 560 SL
1930 Ford A Roadster
1914 Ford T Speedster
OldWorldShepherds is offline
post #3 of 5 (permalink) Old 04-30-2013, 01:51 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
You can find the Factory Manual here on EPC Startekinfo. Scroll down-I think it's on page 2 or 3.
http://www.startekinfo.com/StarTek/doclist.jsp
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #4 of 5 (permalink) Old 05-01-2013, 06:13 AM Thread Starter
Great, thanks guys. need to sort a high idle prob, Im a bit young for jetronic!!! but with some basic info will no doubt rectify it. suspect air regulator..
post #5 of 5 (permalink) Old 05-05-2013, 06:59 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
116 engine.
yes the air regulator is sticking and needs a thorough clean up . Remove and put overnight in a descaling solution allowing all the crud to dissolve, the thermostat plate will operate full length bringing the RPMS down as the water temp rises.
just sorted out a friend's 450se .worked!
Adler
adler is offline
