Electric Windows Fuse Box location? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-22-2013, 07:51 PM Thread Starter
Date registered: Apr 2013
Vehicle: 1970 280s, w108.016, 2.5L
Hi guys. My driver's side window is in down position and will not go up. Other 3 windows work fine. Hoping it's a fuse but can't find. Owner's Manual says they're under the hood on passenger side. I must be blind. Can't find. Any tip will be most appreciated.
1970 280s
rherro is offline
post #2 of 4 (permalink) Old 04-22-2013, 08:25 PM
Date registered: Aug 2009
Quoted: 49 Post(s)
Not a fuse. The fuses are staggered. LF and RR are on one circuit. Same for the RF and LR.
Probably the switch as this is the most used one.
Mike D is offline
post #3 of 4 (permalink) Old 04-23-2013, 07:06 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 1968 250S, 1991 300se, 1998 SL500, 2x 1977 450SEL 6.9. Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 405 Post(s)
fuses should be in drivers footwell I think.
Time to remove door panel and check for voltages to rule out switch or motor.
rumb is offline
post #4 of 4 (permalink) Old 04-23-2013, 09:01 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
to test that window , turn ign on , in garage [ may need some darkness ] , watch the red dash light that is on , now , push switch to down position , does dash lite dim some , if so the window want to go down , repeat for up position , if lite does nothing , you have a bad switch , if lite dim some , motor is stuck .if bad switch , try electronic spray cleaner .
agillot is offline
