W114 Carbs\engine problem - Page 9 - Mercedes-Benz Forum
post #81 of 93 (permalink) Old 05-07-2013, 03:12 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
The sync tool looks like this.
Top five reasons I posted in your topic:
1. You're talking about god, there has never been any god of any kind. EVER!
2. I just have a general dislike of you.
3. I am trying to tell you how to fix your Mercedes and you are not listening.
4. I'm flirting with Jody.
5. You're just to dumb to own a Mercedes, and should go buy a Honda.
Mercedes mechanic is offline
post #82 of 93 (permalink) Old 05-07-2013, 04:36 PM
Date registered: Aug 2009
Quoted: 57 Post(s)
Originally Posted by Mercedes mechanic View Post
Lets not forget too, on the 2+2 setups the carbs had to be perfectly tuned.
And THAT, good sirs, is the Lord's honest truth!
If your carbs are not sync'ed then I don't care what you do to timing, valve adjustments, cam timing offsets or any other hoo-doo you wanna try, your engine WILL run like poo-poo.
I modified my M115 to run on an aftermarket fuel injection system because I got tired of fiddling with the twin down draft Solex'es it originally had.
Mike D is online now
post #83 of 93 (permalink) Old 05-07-2013, 05:56 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the 4 deg ATDC, was a smog issue , it did use a retard vacuum box on the distributor and some electrical solenoids to activate .it is rare to find a car that has those solenoid that work .so , what you do , is not using the vacuum retard , and time car to 5 to 10 BTDC .the engine will idle much better .use timing specs for a older 250s .[ 67 or so ].
agillot is offline
post #84 of 93 (permalink) Old 05-07-2013, 06:30 PM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Do I remove the vacuum lines from the distributor or leave them there?
kavadarci is offline
post #85 of 93 (permalink) Old 05-07-2013, 09:24 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Euro models did not have this bit of smog add on ; the engines run very smooth and briskly .
adler is offline
post #86 of 93 (permalink) Old 05-08-2013, 12:25 PM
Luna Gaudi's 72 250's Avatar
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
Update On my timing. I removed the retard vaccum to the distributer and adjusted the timing by ear. (i need to buy a new timing light) There was a slight but noticeable difference in power. The engine is more responsive and happier now.
Luna Gaudi's 72 250 is offline
post #87 of 93 (permalink) Old 05-11-2013, 08:54 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
More info thanks to Mark.
My vacuum lines are little bit confusing. The carb vacuum line instead of going to the valve just goes directly to the second carb. The distributor vacuum top connection line goes directly to the lower connection.
Disconnecting the lines does make a difference on the engine idling
Why would anyone set the vacuum lines like this? Is it because the valves don't work and they managed to "bypass" the problem? How can I check if the valves are working?
I think this has to do with the engine not working properly
Thank you
post #88 of 93 (permalink) Old 05-12-2013, 06:32 PM
Take some pictures please.
post #89 of 93 (permalink) Old 05-12-2013, 09:03 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
ok, here are some pictures with explanations.
Basically i have now the lines connected as per Mark's suggestion excluding the emission line at the bottom of the distributor, that is now plugged.
The car works much better and i can "feel" the engine but still not there as now probably needs timing adjusted again which i don't want to do until i get the air filters and the air flow gauge.
i am completely puzzled why would someone connected the lines like this.
ID:	514685   Click image for larger version
post #90 of 93 (permalink) Old 05-12-2013, 09:53 PM
Quoted: 17 Post(s)
this.
When you say "excluding the emission line at the bottom of the distributor" is this what you are refering to? (see photo)
If so, this is to retard the timing, mine is now disconnected and plugged with a rubber cap.
In the first photo, is the vacuum pipe that is connected to the dashpot going into the vacuum on the bottom of the front carb?
If so, then someone just bypassed the two way valve, and that should work.
(Mine is currently going through the two way valve)
In the second photo, you CAN bypass the three way valve and hook one of the carbs vacuums into the top (advance) of the distributor.
That is how mine is currently connected.
As per testing the two and three way valves, I have no idea how to do that. We need some expert advice on this one please.
