W114 Carbs\engine problem - Page 3 - Mercedes-Benz Forum
post #21 of 93 (permalink) Old 04-24-2013, 07:46 PM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 82 300D,90 350SDL, 98 S420, 97 SL500, 94 S420, past owner W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 660 Post(s)
I don't know that the stops missing is an issue, as the flap inside won't allow them to move beyond a certain point anyway. I suspect they are there to prevent any stress on the flap, since the weights are pretty substantial.
Where the function of the flap makes a difference is in cold start and warm ups. By heating the plenum the mixture is rapidly warmed, making the engine run better and allowing the enrichment circuits to close off more rapidly. It's an efficiency thing more than anything else.
Dan
LWB250 is online now
post #22 of 93 (permalink) Old 04-24-2013, 08:04 PM
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
So then its really not necessary to fix if I am happy the way the engine is running?
Luna Gaudi's 72 250 is offline
post #23 of 93 (permalink) Old 04-25-2013, 05:53 AM
Date registered: Jan 2007
Quoted: 82 Post(s)
I fixed the flaps on a couple of my cars and didn't observe any difference in warm-up. My fintail has the same arrangement but with Solex carbs. A couple of years ago I had the manifolds off to fix a vacuum leak and I had the machine shop secure the flaps in the closed position. No issues with warm-up.
That would be my recommendation rather than trying to fix the opening/closing mechanism.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #24 of 93 (permalink) Old 04-25-2013, 06:01 AM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Ok, I will not concentrate too much on the heat risers.
Can someone advise looking from the front of the car at the engine which one is in and out valve? I am also getting conflicting information on the gaps, what should the valve gaps be set to?
Thank you.
kavadarci is offline
post #25 of 93 (permalink) Old 04-25-2013, 08:08 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 444 Post(s)
You can tell which valve it is by matching up with the intake/exhaust runner.
Look at picture, round is intake, square is exhaust.
Exhaust: 0.008 inch
Intake: 0.004 inch
Thank you.
rumb is offline
post #26 of 93 (permalink) Old 04-25-2013, 06:32 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
when you have warped top housing on the cabs , the fix we used to do , is putting them on a flat surface , and hitting at center with hammer , this would work everytime . the flat surface could just be a clean concrete floor .
agillot is offline
post #27 of 93 (permalink) Old 04-25-2013, 07:49 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
ok,
i need to understand which position is open and closed for the heat risers.
looking from the front of the car at the engine the first flap is stuck into upper/right position and the second i can push lower/left position where the lower stoppers are.
Can i visually tell that i have warped carb plate without removing anything?
and third, :-) how do i turn the engine manually, i have the car in neutral and all the plugs out and via the belts this thing is not moving at all.
Thank you.
post #28 of 93 (permalink) Old 04-26-2013, 02:44 PM
Quoted: 17 Post(s)
I personall have not had to adjust my valves as of yet, but this is per a repair manual.
The valve clearances should always be checked when the engine is cold. Try turning the crankshaft by means of the pulley bolt until the long profile of the camshaft lobe nearest the front of the engine is pointing upward (cam base circle of camshaft next to rocker arm) Now insert a feeler blade between the cam lobe and the rocker arm to the specifications. The feeler blade should be a stiff sliding fit. If it is not, adjust the clearance by turning the ball pin. The ball pin has stiff threads and is self-locking. Where it is found that moving the ball pin still does not provide enough clearance between the camshaft lobe and the rocker arm then an alternative thickness thrust piece should be obtained and fitted. These thrust pieces are available in several different thicknesses. When the first (exhaust) valve has been checked, continue with the next valve and so on. If the firing order of the engine is followed (1-5-3-6-2-4) it will avoid excessive rotation of the crankshaft. Remember that the inlet and exhaust valve clearances are different so identify the valve carefully before checking its clearance. Refit the spark plugs and rocker cover.
post #29 of 93 (permalink) Old 04-26-2013, 02:45 PM
Quoted: 17 Post(s)
As per my heat risers. I'm not too sure either. I will try to get in there and figure it out,
post #30 of 93 (permalink) Old 04-28-2013, 04:05 PM Thread Starter
kavadarci's Avatar
Vehicle: 1971 250C
Quoted: 14 Post(s)
here is an update:
i have measured the compression on each cylinder and here are the numbers:
1. 100psi
5. 100psi
3. 120psi
6. 130psi
2. 120psi
4. 100psi
are these numbers normal?
what is the expected compression for this engine?
thank you.
