W111 turn signal issues - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-22-2013, 03:25 PM Thread Starter
Date registered: Jul 2005
Vehicle: W212 E250 Bluetec 4Matic, W210 E55 AMG, W202 C43 AMG, W126 300SE, W111 220SE
Quoted: 7 Post(s)
The signals on my fintail are being weird...has been doing it off and on for years, but lately is worse. I think the blinker regulator or whatever the silver cylinder on the firewall is called is dying. For some years, every now and then the signals would act up - blinking at inconsistent rates, too dim, etc - but then would turn around and work normal. Today I removed the cylinder, cleaned the plug, plugged it back in - worked for a few minutes, now is weird again, sometimes not working at all.
Is there anything else that could be wrong, and is this part easy to come by/interchangeable with others?
HockeyGod is offline
post #2 of 4 (permalink) Old 04-23-2013, 06:09 AM
67300se5spd's Avatar
Date registered: Dec 2006
Vehicle: 2004 E320
Quoted: 10 Post(s)
Sometimes it's the actual column switch . In my case a few soft taps on the silver cylinder under the dash , near the steering column, did the trick...Here's one on Ebay....You may be able to get it cheaper if you search around but for reference...
Mercedes Blinker Turn Signal Flasher Relay New | eBay
For proper fitment, call the Classic Center and give them your vin # . They'll give you the part # you need....
67300se5spd is offline
post #3 of 4 (permalink) Old 04-23-2013, 12:02 PM Thread Starter
Quoted: 7 Post(s)
Thanks. Just wanted to know if the issues could be caused by the "blinkgeber". My car also does have some switch issues - moving the stalk to different positions provides varying results. I guess after 50 years, some of this stuff needs to be cleaned and adjusted
I also found this on ebay, which is identical to my part and the number on it. I don't know if my car would reject the non-German organ transplant, however
Mercedes Bosch Turn Signal Relay New 001 544 39 32 | eBay
post #4 of 4 (permalink) Old 04-24-2013, 03:32 AM
Vehicle: 2004 E320
Quoted: 10 Post(s)
The stalks can be rebuilt / adjusted ....
That flasher unit is a good deal !
Bosch is made all over the world now.....Your car won't mind the part not originating in Germany....
