Need a Temp Gauge Sending Unit-1961 190c - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-12-2013, 12:07 PM Thread Starter
NorCalSL's Avatar
Date registered: Jun 2007
Vehicle: '70 280S-'73 450SLC-'81 380SL-'84 500SEC Euro-'92 300SL24-'95 E320
Quoted: 22 Post(s)
Exclamation Need a Temp Gauge Sending Unit-1961 190c
Good Day All,
Does anyone have the part or a lead to the correct part, temp gauge sending unit for my 1961 190c. Looks a little odd, see pics.
Thank You
dws
ID:	508656   Click image for larger version
1973 Mercedes 450SLC (PineGreen/MahoganyLeather)
1981 Mercedes 380SL FORSALE (LtIvory/PalominoMBTex)
1984 Mercedes 500SEC Euro (040Black/BlackLeather)
1992 Mercedes 300SL-24 Signal Red/Black Leather
NorCalSL is offline
post #2 of 11 (permalink) Old 04-12-2013, 02:22 PM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 82 300D,90 350SDL,90 300SEL,98 S420,97 SL500,94 S420 former W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 730 Post(s)
You have a temperature gauge that uses a capillary tube, meaning the "sender" and the braided cable you see with it are all one piece all the way to the gauge. It's not a separate piece - you have to replace it as a unit, that is, the gauge and the capillary tube are a unit.
Dan
LWB250 is offline
post #3 of 11 (permalink) Old 04-12-2013, 03:35 PM Thread Starter
NorCalSL's Avatar
Quoted: 22 Post(s)
Thank you Dan, I did not know that and better to learn that now instead of after I broke it, Thank you for taking the time to respond.
Happy Motoring
dws
NorCalSL is offline
post #4 of 11 (permalink) Old 04-12-2013, 07:58 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
temp gauge
Perhaps a better source would be a P&P ora EBay buy .NOS can be pricy !
As this gauge is common to all 110, 111 and 112 models a gauge from any one of these models will fit directly.
Ad
adler is offline
post #5 of 11 (permalink) Old 04-13-2013, 10:19 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
those old style gauges are fixable [ new end ] common problem . some.speedo shops do this kind of repair .
agillot is offline
post #6 of 11 (permalink) Old 04-18-2013, 10:31 PM
Date registered: Apr 2013
Repair on temp gauge
I was told that the temp gauge on the w110 body style contained mercury, and once line has a hole or broken, the mercury spills out
It's werid, because I swear my temp gauge worked, before I did my restoration, and the line has a small break, and now it doesn't read the temp. Most guys thy have a temp gauge want $195.00. I was going to maybe install an after market gauge if this was true. Can you give me any info???!
1966mercedes200d is offline
post #7 of 11 (permalink) Old 04-18-2013, 11:49 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
Yes, the temp gauges are based on a bulb and capillary tube - so if your tube is cracked it will not work. I had mine repaired in Oz about 2 years ago for about $130 from memory. Do you really want a cheap aftermarket gauge ruiing the look of your car?
drew56cus is offline
post #8 of 11 (permalink) Old 04-19-2013, 12:01 AM
Temp gauge repair
I don't wont a cheap aftermarket temp gauge. My car is OEM on the dash, with custom interior , but I do want to get it fixed. Where is oz?? Do you have a number and address. I want to get mine fixed. Thanks
post #9 of 11 (permalink) Old 05-31-2014, 03:48 PM
Date registered: May 2014
Vehicle: 1962, 220b (W111 010 50)
NoeCalSL, recently I have posted a way of fixing the teperature unit, if you have not work it you can look to my thread an get your back to work.
They are filled up with ether and not with mercury.
In case your temp unit is not working you can do it your self if wanted by following thr thread.
Miguel
Pilleway is offline
post #10 of 11 (permalink) Old 05-31-2014, 06:24 PM
Premium Member
Quoted: 59 Post(s)
Premium Member
call 619 421 3254 for a used gauge .oneger co .
agillot is offline
