Hot Spark and coil on the way! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-02-2013, 04:20 PM Thread Starter
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
So I ordered up the Hot Spark ignition conversion kit with the matching coil.
(Parts no. 3BOS6U1 and HS17HEC)
I will be taking a lot of photos for an installation write up.
Any advice to ease the installation will be appreciated.
But one thing that I am wondering about, should I go ahead and remove the entire vaccum advance/retard on the distributor and set the timing to a specific degree, or do I need to leave it in there and hook up all of the vacuum lines again.
Luna Gaudi's 72 250 is offline
post #2 of 2 (permalink) Old 04-02-2013, 05:06 PM
Date registered: Aug 2009
Quoted: 49 Post(s)
Hot Spark simply replaces the distributor points and ignition module. Set timing and replace vacuum lines as if you had merely replaced the points. You can open the plug gap a bit if you wish since you will be getting a cleaner/hotter spark. .032"-.036" as opposed to the .028" recommended for the OEM ignition set-up.
Mike D is offline
