w115 tail lamp diagram help - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-26-2013, 07:27 AM Thread Starter
Date registered: Jul 2012
Vehicle: 1975 300d
on my w115 the drivers side left rear parking lamp is not working. when i tested the socket the power and ground are ok. when you twist the bulb in the socket switches from ground to power and the bulb is inop. i plugged the right side lamp in with the same result. any ideas? ps i switched bulbs too.
ncstroke8 is offline
post #2 of 4 (permalink) Old 03-26-2013, 10:10 PM
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Take it apart and see if the board has any cracks causing to loose connection, there is nothing else.
kavadarci is offline
post #3 of 4 (permalink) Old 03-27-2013, 11:37 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Sometimes the simple solutions can solve a major headache. I had one backup light that kept going out, I'd replace bulbs, clean the base, but nothing worked and all it took to resolve it was to add a little bulb grease to the base. You can buy it in small packets from auto parts stores and those will last you a long time since you only use very little. It's worth a try.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #4 of 4 (permalink) Old 03-29-2013, 07:14 AM Thread Starter
Vehicle: 1975 300d
just the fact that i have tried 2 boards with the same result is making me think its a wire issue when a load is applied. ill try grease on the bulb and on the plug in the trunk.
