1964 220Sb Front Calipers, does anything else fit - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-25-2013, 04:01 PM Thread Starter
Date registered: May 2012
Vehicle: 1964 220S
Hi, both my front brake callipers are shot, the pistons are rusty and the seals have disintegrated, I was just wondering if anyone knew if anything else fits either from a later model Merc or from a different car. Mine has the 3 piston ATE type and I can't find replacement pistons here
Elkie is offline
post #2 of 4 (permalink) Old 03-26-2013, 05:36 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
quite a few later ones will fit including ones from a 108 250S, 280S 66-71 era.
adler is offline
post #3 of 4 (permalink) Old 03-26-2013, 08:46 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Any f caliper from 108, 109, 110, 111, and 113 chassis 6-cylinder 1965-71 will work fine -- you'll need to swap both fronts, and use different b/pads, but they'll work like a charm.
GeeS is offline
post #4 of 4 (permalink) Old 03-27-2013, 02:49 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 32 Post(s)
I don't necessarily believe you can't get pistons for the 3-piston calipers anymore. I had mine rebuily about 2 years ago - it turns out that Humber (Super Snipe from memory) used the same pistons. But they were expensive. Better to just get the regular ones and fix them if required.
drew56cus is offline
