Front door speakers - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-24-2013, 04:36 PM Thread Starter
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
Front door speakers
hi,
has anyone installed speakers in the front leg area on a W114/15?
i want to put 6 1/2 speakers on each side at the front and two in the back.
I am dealing with the back but i don't know how much space is available if one wants to cut in the foot side area under the dash.
i want the speakers not to be visible with the highs where the original center speaker was.
Thank you.
kavadarci is offline
post #2 of 6 (permalink) Old 03-24-2013, 06:11 PM
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
My 114 did have some small speakers that were flush mounted at the feet area side panels, when I gutted the car, I wanted to put some larger speakers in that area, but there was only enough room to flush mount a 4" speaker. I went with some Kenwoods model # KFC1094PS because I found them locally and they came with grilles. To my suprise, alot of speakers now days do NOT include a grille. They fit perfectly in the space that was there without any other cutting of the metal. They sound ok, I think they would sound a lot better if I had ears on my ankles. (ps working on the install write up for you)
Name:	Luna Gaudi 13.jpg
ID:	504750   Click image for larger version
Name:	Luna Gaudi 23.jpg
ID:	504751   Click image for larger version
Luna Gaudi's 72 250 is offline
post #3 of 6 (permalink) Old 03-24-2013, 08:26 PM
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
i made all new door panels with eclosures for speakers. they look really nice and factory. i put 6.5 alpine type r separates. i have te same speakers in the rear. As for subs I have 2 alpine 12 type r. amps are a 240 watt 4 channel alpine for the separates, and 2 jl audio 500.1 for the subs. Sound deadening all over the car. and yes..... it sounds killer lol
madmanmerc is offline
post #4 of 6 (permalink) Old 03-27-2013, 07:21 PM
DerFuror's Avatar
Date registered: Apr 2009
Vehicle: 1993 MB 500E, 1965 MB 220b
Kick Panel Speakers
I surface-mounted a set of speaker pods to my front kick panels. Doesn't require any cutting of sheetmetal. The pods do (or did) come in different size & color configurations, or they can be painted to match interior.
Here's some pics taken a few years back while figuring out the installation's final placement.
DerFuror is offline
post #5 of 6 (permalink) Old 03-27-2013, 07:32 PM
Quoted: 17 Post(s)
Do you find that they stick out too much or has anyone accidently kicked them? I really like how that angle sends the sound more to your head area and not the ankles like my setup is now.
post #6 of 6 (permalink) Old 03-27-2013, 08:08 PM
DerFuror's Avatar
The woofer portion of the pod protrudes about equal to that of the inner door sill located directly below it. Since a passenger must step past the sill into the footwell, they also must step past the pod which is up higher out of the way.
The W111 has an expansive footwell. So far so good with no accidental kicks from any passengers. No interference while I'm driving, or entering/exiting either.
The angle definitely directs the sound up to the front seat occupants. Makes a huge sonic quality difference in the vehicle.
(BTW, your car has a very cool-looking interior)
DerFuror is offline
