Symptoms of a failing Ignition Control Module? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 03-19-2013, 08:54 PM Thread Starter
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
What are the symptoms of a failing control module? Is it possible for it to work and then not work and then work again? The car started right up, and as I slowly pulled out onto the road from my driveway I hit the accelerator and the car pulled hard as usual then almost immediately the car died. I tried to restart and nothing. Luckliy, I was only about fifty feet from my drive way and a friend help me push it back. First thing that I checked for was spark. There was nothing at the plugs or coming out of the coil. I assumed it might have been the coil so I orderded one up because this the one that is on the car is the original 40 year old coil. Today, I had a chance to pull out the trusty meter and started to diagnose the problem. With the ignition on, I seperated the contact on the points and checked for any voltage reading from ground to the positive wire on the coil, there was nothing.(per Haynes book) I checked the ignition switch to see if everything was plugged in tight, it was. Checked for continutiy on the resistors, they were fine. So I decided to pull out the control module, everying was plugged in tight. I removed the screws from the back of the moduel and peaked inside. Although everything in there was covered with a redish brown "sealer" nothing looked like it had burned out. I put the cover back on and hooked it back into the car. With the ignition on, I checked with my meter again, one lead on ground and the other to the positive wire on the coil and now, it's showing power. I got back in the car and it started right up! Any thoughts or suggestions? My friend that was helping me had accidently dropped the module on the ground, that couldnt have got it back to working order? could it? Isn't it all solid state? What are the symptoms of a failing ignition module?
Luna Gaudi's 72 250 is offline
post #2 of 11 (permalink) Old 03-20-2013, 05:00 PM
KCM
Date registered: Jun 2004
Quoted: 17 Post(s)
When it comes to electronic iginition modules, they can fail and have various symptoms ranging from intermittent operation to completely dead. I'll share my experience with my 560SL. My car would normally start and run well. Once in a while after shutting the car off after drving a while (engine warmed up) and then trying to restart, it would not start. After sitting for 20 or 30 minutes the car would start right up and run good. This symptom is common with electronic modules and ignition coils where something inside shorts out after the unit heats up either from being on or from heat absorbed from the engine. After a while my car failed to start even with the engine cold (no spark), then out of the blue there was spark and it started and ran fine again. I changed the coil (thinking it was shorting out when hot) and the ignition pickup to no avail. Finally changed out the ignition module for another used one and have had no problems since. It was definitely the module failing intermittently.
Not sure how your coil is wired, but if it is similar to my 560SL where it gets power through the module, then I'd say the module could definitely be the culprit. Maybe a loose terminal or solder point that again made contact when dropped.
KCM is offline
post #3 of 11 (permalink) Old 03-20-2013, 09:21 PM Thread Starter
Quoted: 17 Post(s)
Thanks for the input. I am heading to the old boneyard to see if I can pull one off of the 280 thats sitting in there. I figure I might keep an extra modual in the trunk and just in case, be able to swap it out on the side of the road in about twenty minutes. I really don't want to spend $ 1,400.00 for an oem modual.
post #4 of 11 (permalink) Old 03-22-2013, 07:55 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
remove module , replace coil with a standart ignition coil , install a condensor at the coil minus [ going to pointes ] ground body of condensor with a wire / hose clamp . you will have to modifie wirring to coil , ignition to plus of coil , and minus to pointes . coil num 000 158 49 03 , condensor 000 156 81 01 .and a ballast 000 158 08 45 [ 0.9 ohm ] or use one that you have on car , close to that value . you could also use a us car set up , coil , condensor / ballast out of a 60 s car .
agillot is offline
post #5 of 11 (permalink) Old 03-22-2013, 11:42 AM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 115 Post(s)
Yes, they can fail intermittently. Also check your points.
With best regards
Al
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
My 280SL restoration
alabbasi is offline
post #6 of 11 (permalink) Old 03-23-2013, 07:09 PM
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
[QUOTE=Luna Gaudi's 72....swap it out on the side of the road in about twenty minutes. I really don't want to spend $ 1,400.00 for an oem modual.[/QUOTE]
Alternately an excellent replacement would be a pertronix electronic unit ,fits under the cap and works very well all for under $100.
15 years on my car with flawless performance .
adler is offline
post #7 of 11 (permalink) Old 03-24-2013, 11:13 AM Thread Starter
Quoted: 17 Post(s)
Adler, I think you might be right here. I probably should upgrade to the pertronix unit. Could you give me some more info on where to buy and any tricks or hints to install. It will be on a 1972 250. The engine was replaced with another about 12 years ago. I'm not too sure if the replacement engine was the same as the stock one. On the engine that is currently in the car, the drivers side of the block is stamped "280S / A". Is that a 2.8 liter and will that effect the type of pertronix unit that I should buy?
post #8 of 11 (permalink) Old 03-25-2013, 09:18 AM
Quoted: 59 Post(s)
okay that is a M130 engine .The kit installation is simple and easy with the instructions provided.
i got all my kits from 'retrorockets ' but there are quite a few other ones if you google pertronix kit.
aAd
adler is offline
post #9 of 11 (permalink) Old 03-25-2013, 02:40 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
You should really look on the distributor itself for a little metal ID tag that has a number on it, as this is what is important when ordering a pertronix. ponderosamustang on ebay sells them too. Have a look on the engine for stamped numbers (not cast) that start with 130 - that will be the engine number.
Cheers,
Drew
drew56cus is offline
post #10 of 11 (permalink) Old 04-01-2013, 12:36 PM Thread Starter
Quoted: 17 Post(s)
I couldn't really find a metal ID tag. It only looks like a part number, could this help me to buy the correct Pertronix?
0 231 187 002
JFU 6
