Tune-up / chasing oil leaks - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-27-2013, 11:33 AM Thread Starter
Date registered: Dec 2012
Hello everybody, I am trying to get my 220d back into daily driver condition. its a pretty good running car but it has its issues. im hoping a few of you can help me with these issues.
fist off it has a pretty bad oil leak. i have cleaned it and had it on stand multiple times but it doesn't leak too bad when im just idling. its after my 25 mile commute and i park it that an hour later when i come out to check on it that there is a puddle of oil on the drivers side. i have also noticed a couple time a spray pattern of oil on the front passenger side. i replaced the oil pan gasket as i thought that could be part of the problem but it doesn't seem to have helped.
any other trouble spots to check on the front end. anything that would spray oil on the passenger side?
also, the engine seems to run a bit rough, i'm new to diesel engines and it doesn't seem sound too bad but i thought while i am working on the car i would do a tune up. any suggestions on how and what i tune up?
thanks for any help and suggestions.
coreyt is offline
post #2 of 7 (permalink) Old 02-27-2013, 12:05 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 458 Post(s)
Are there cooler lines going to the radiator? Other than that just detective work, start with clean engine and see where leaks are from. If there is a puddle after and hour, go watch 15 min after you park. Oil filter on tight?
rumb is offline
post #3 of 7 (permalink) Old 02-27-2013, 12:24 PM Thread Starter
thanks for the advise, yes there are cooler lines to the radiator but im pretty confident they are not the issue. I have tightened up the filter and replaced the oil pan gasket but the issue persists.
coreyt is offline
post #4 of 7 (permalink) Old 02-27-2013, 02:17 PM
Date registered: Jan 2012
Send a message via Skype™ to An.vil
I had a similar issue with my 300D. A lot of the leak was contained when the crankshaft seal was replaced. It continued to leak however and everything indicated that it was the seal underneath the head so I gave up on that one. Hope it helps. Other than that I would check all the fuel lines I was surprised how the old lines leaked through the cracks, messed up the engine and of course my MPG was pretty bad. After that I was getting 30mpg
An.vil is offline
post #5 of 7 (permalink) Old 02-27-2013, 02:41 PM Thread Starter
This is very helpful, may i ask did you have the front or rear crank shaft gasket replaced or both, from my research you cant replace the rear gasket without pulling the engine. is this correct? so you also had a head gasket leak? this gives me more to go on. thanks,
Corey
coreyt is offline
post #6 of 7 (permalink) Old 02-27-2013, 03:29 PM
Corey
Hi Corey,
Yes I did replace only the front one (that's the main suspect in most cases of oil leaks) as far as I know you would have to pull out the engine in order to replace the rear gasket. I'm not sure if it is the head gasket leak, it seemed like it is the seal that is in the middle of the engine sealing the middle piece of the engine (between the lower part of the engine and the heads). I hope it helps. For the head gasket you probably wouldn't need to pull the engine out.
An.vil is offline
post #7 of 7 (permalink) Old 02-28-2013, 11:48 AM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
I have a '73 220d (wonderful car) and had similar oil leak issues. The big culprit was the front crank shaft seal. In my case I had to replace not only the seal but the metal ring in the engine (the outside part the seal seals to).
But I had 200K miles on the engine then. There is a special tool to pull this ring - good luck finding one although my local German car mechanic (an older fellow) had one. He was impressed that he got to use it again.
The thing about the crank shaft is normally it is not under the oil level so stopped or low idle no leak. At higher speeds the oil splashes around and some comes out. It can drip down or get onto the pulley then get flung anywhere. Then when you stop the oil drips off the outside of the engine.
In any event the used diesel oil is black nasty stuff and I'm sure you want to fix this leak for your driveways sake.
Frank
Sent from AutoGuide.com App
Frank Flynn
'73 220D
'88 300SEL
'91 300TE
frankflynn is offline
