Question for w114/w115 owners - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-16-2013, 01:45 PM Thread Starter
74benzo's Avatar
Date registered: Sep 2009
Vehicle: '74 280
I am trying to remove my gauges and I have a cable that goes through a bolt near the middle that I believe operates the gear selector indicator. How do I remove this?
1974 280
2001 Lexus IS300
74benzo is offline
post #2 of 7 (permalink) Old 02-17-2013, 05:31 AM
Date registered: Aug 2009
Quoted: 60 Post(s)
Never seen a '74 W114 with a gear selector cable. The only ones I've seen are console shifters. Are you referring to the speedo cable? If so, there is a clamp down on the firewall which you can undo to give you a bit more slack in the cable. This will five you more room to unscrew the speedo cable.
Is this a diesel? My '74 280C gasser has an electronic oil gauge but the diesels may still have the manual gauge. It will be a thick plastic line on the left hand side of the cluster. 10 MM wrench to remove it.
Mike D is online now
post #3 of 7 (permalink) Old 02-17-2013, 05:40 AM Thread Starter
74benzo's Avatar
Vehicle: '74 280
No, it's definitely for that. My car has the gear selector on the steering column. When I tighten and listen it, it changes how accurate the needle is.
1974 280
2001 Lexus IS300
74benzo is offline
post #4 of 7 (permalink) Old 02-17-2013, 07:19 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the cable hooks at the shift lever , it is very visible , carefully unhook [ fragile ] , then slip of the sleeve of the bracket .if you look under dash , you clearly see everything .
agillot is offline
post #5 of 7 (permalink) Old 02-17-2013, 12:17 PM
tedg's Avatar
Date registered: Jan 2012
Vehicle: MERCEDES BENZ 230 W115 1974
[QUOTE=74benzo;5656029]No, it's definitely for that. My car has the gear selector on the steering column. When I tighten and listen it, it changes how accurate the needle is.
Yes I am going to have to do the same thing on my 74 230...Its PRNDL21 is out of whack....does anybody have any tips on this or is it self explanitory?
I dont think I have replace the whole cable do i?....
thanks.....
I love to learn.. I dont always like being taught.
tedg is offline
post #6 of 7 (permalink) Old 02-17-2013, 08:53 PM Thread Starter
74benzo's Avatar
Vehicle: '74 280
When I tighten or loosen the screw on the back of the gauges it makes it move and you can put it how how you need it. Can anybody tell me how to get heat to come from the center vents please? It only comes from the ones on the sides.
1974 280
2001 Lexus IS300
74benzo is offline
post #7 of 7 (permalink) Old 02-18-2013, 08:41 AM Thread Starter
74benzo's Avatar
Vehicle: '74 280
That did work agillot. Thanks!
1974 280
2001 Lexus IS300
74benzo is offline
