Rear Brakes ??? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-14-2013, 04:07 PM Thread Starter
helleifenbein's Avatar
Date registered: Dec 2011
Vehicle: 1967 W108 250s
Quoted: 9 Post(s)
Rear Brakes ???
This week Ive dedicated some time to rebuilding my rear calipers. Received my parts from Auto haus AZ. I have since become aware that my w108 has two different sizes of pistons used in the calipers (Driver side big passenger side small) I'm thinking this is the stock set up because of the added pressure regulating valve mounted by the rear axle. Has anyone run into this and what is the correct rebuild kit for the passenger side rear from Auto hausaz or another supplier???
also the drivers side uses piston guides in the calipers and the passenger side does not.
If anyone could shed some light Id be thankful
Cheers
Dave
helleifenbein is offline
post #2 of 3 (permalink) Old 02-14-2013, 04:57 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the pistons are same size on both sides , one is the wrong one .the kits numbers are 000 586 15 43 .calipers are 000 420 46 83 left and 47 83 right .
agillot is offline
post #3 of 3 (permalink) Old 02-14-2013, 06:16 PM Thread Starter
Quoted: 9 Post(s)
That is just wonderful. I thought I recalled reading somewhere they were different sizes. couldn't find the article. might have been front to back. Guess Ill replace the passenger rear side as the driver side caliper is the correct size for the rebuild kit. Looks like this was somebodies wrecking yard fix, noticed the bleeding valves are a little different also.
Thanks for the help thinking this through.
