W 108 - bad left outer able bearing - fix or swap rear ends? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-03-2013, 12:23 PM Thread Starter
Scoot's Avatar
Date registered: Oct 2002
Quoted: 129 Post(s)
My 1967 250S is now amongst the living. There is a rhythmic sound that comes from the right rear axle about 10 inches in from the wheel. I suspect the bearing.
I have a 1968 280S parts car that I think has a quiet rear axle.
Thoughts?
Scoot is offline
post #2 of 6 (permalink) Old 02-03-2013, 03:30 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
axle bearing
On my 280S i had a loud clicking noise from the right rear wheel bearing rectified after a bearing replacement .
The availability or price of the bearing may help you decide to swap or replace the bearing .
Ad
adler is offline
post #3 of 6 (permalink) Old 02-03-2013, 03:31 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
if it is just a bad wheel bearing on r side , it would be easier to replace that bearing .you need 2 thing , 0019811525 bearing , 111 350 00 68 seal kit , and 2 108 423 00 92 springs [ optional ] and a 108 shop manual .
agillot is offline
post #4 of 6 (permalink) Old 02-03-2013, 03:49 PM Thread Starter
Scoot's Avatar
Quoted: 129 Post(s)
I'm looking in the shop manual and it reference two mercedes tools needed - one of which is used to bang the axle out of the axle tube. Is this something that I can do or a basic mechanic can do, or are special Mercedes tools (and/or a press) required to do this?
thanks
Scott
Scoot is offline
post #5 of 6 (permalink) Old 02-04-2013, 07:23 AM
helleifenbein's Avatar
Date registered: Dec 2011
Vehicle: 1967 W108 250s
Quoted: 9 Post(s)
I just recently finished that task on my 67 250s, getting the axles out is pretty easy. i used the drum flipped around with the lugs a bit loose. yanked on it, and it came right out. getting the bearing off the axle and installing the new one are the most challenging, but not impossible. I posted some pics as I met the challenge on here. Oil seal replacement
helleifenbein is offline
post #6 of 6 (permalink) Old 02-04-2013, 04:21 PM Thread Starter
Scoot's Avatar
Quoted: 129 Post(s)
... and 2 108 423 00 92 springs [ optional ] .
I'm curious as to why I would replace these two springs (which I will order today). Also, for my car it appears to be A 000 423 21 93 as the chassis break to the other part number is at chassis 040645 and I have 037497...
thanks
Scott
Scoot is offline
