W111 230S Newbie Needs Your Guidance! - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 01-03-2013, 10:09 AM Thread Starter
Premium Member
MadColonel67's Avatar
Date registered: Dec 2012
Vehicle: 2004 E500 4Matic Wagon, 1980 450SLC, '94 SL500
Quoted: 14 Post(s)
Premium Member
As I await the arrival of my 230S (coming to CT from WA), I need to order some parts and prepare a list for my mechanic. I received this information from the seller
Engine oil: 10/40, and it's fairly fresh, low miles.
Transmission: Needs changing
Coolant: new, replaced after draining the system for heater box rebuild.
Brake fluid: worth replacing, it's old.
Differential: never checked.
Power steering fluid: stays full, doesn't leak, not sure what is there.
Chassis lube: should be checked.
Air filters: should be checked.
Fuel filters: should be replaced.
He's had it for 2-years and rarely drove it because he left the country for 9 months. The previous owner was the grand daughter of the original owner and the service records indicate it was properly cared for by the local M-B dealer. Including a valve job at 111,000 kms.
Can you folks tell me what is recommended for each one of these routine service tasks including where I can get the proper filters? It has the original dual carbs still mounted.
ID:	487752   Click image for larger version
ID:	487753   Click image for larger version
Name:	PS SIDE FULL.jpg
ID:	487754   Click image for larger version
ID:	487755   Click image for larger version
Name:	PS FRONT CLOSE.jpg
MadColonel67 is offline
post #2 of 16 (permalink) Old 01-06-2013, 08:57 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Nice car.These models-w111 fintails are solid and very dependable .
For one i would install a pertronix electronic ignition kit for perfect starts and to do away with ignition point servicing.
Ad
adler is offline
post #3 of 16 (permalink) Old 01-07-2013, 06:45 PM
OldWorldShepherds's Avatar
Date registered: Jan 2012
Vehicle: 1989 560 SL - Signal Red & Palomino; 2011 C-300 - Black on Black 4MATIC
Quoted: 91 Post(s)
Congrats on a nice find Colonel; will look for you at local shows here in snowy (for now) CT come spring. Ken Marino in Durham services mine and we have been happy. I know there are a couple others closer to you if you have not already established a relationship with an MB specialist. Most of your needs now seem basic, however, good to have a little PM done so you are ready to go in a couple short months.
1989 Mercedes 560 SL
1930 Ford A Roadster
1914 Ford T Speedster
OldWorldShepherds is offline
post #4 of 16 (permalink) Old 01-07-2013, 06:51 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
if your mechanic knows what he is doing , he wont need a list .
agillot is offline
post #5 of 16 (permalink) Old 01-07-2013, 07:39 PM Thread Starter
Premium Member
Quoted: 14 Post(s)
Premium Member
Well, that's a good one. I trust my mechanic and yes he won't need a list. But the request for information was meant to make me more familiar with what is correct. I didn't think it unreasonable to ask. I appreciate the sentiment though.
post #6 of 16 (permalink) Old 01-07-2013, 11:13 PM
Date registered: Apr 2012
Originally Posted by MadColonel67 View Post
Follow us on Twitter at: http://twitter.com/@itsmint2me
Todays great finds at: Index of /
FYI: Today's great find is apparently AWOL.
Got a server level error...
Palolo is offline
post #7 of 16 (permalink) Old 01-08-2013, 06:08 AM Thread Starter
Premium Member
Quoted: 14 Post(s)
Premium Member
Yeah tell me about it, Palolo! We are launching a new site that was to be up by now. And like all great plans...thanks for trying and I let you know when it, like Lazarus, rises from the digital dead.
post #8 of 16 (permalink) Old 01-08-2013, 08:59 AM
wbain's Avatar
Date registered: Dec 2003
Welcome to the club. Beautiful car and nice Euro lights.
Use Diesel oil because regular oil does not contain ZDDP which protects rotating parts from wear. Changed by EPA order to protect catalytic converters.
Uses ATF, the fillup plug is on the front passenger side towards the front of the trans and requires a 14 mm hex available from several specialty sellers. The drain is on the bottom of the trans.
Get new hoses including the short one between the water pump and the thermostat housing.
Always use new fresh fluid. Get a Motive Power pressure bleeder. Use only flare nut wrenches. Check the rear slave cylinders for leakage. Repair kits are available.
Check with the axle tubes level. Uses the same 14mm hex tool used for the trans.
Drain and refresh with ATF.
Get a grease gun and a flexible hose. Use quality grease. If you cannot get grease in the zerk fitting, use a heat gun to liquify the old grease and pump in the new. There are many fittings, all front suspension joints, front drive shaft and maybe the slip joint (Your car may have the improved drive shaft with no slip joint.). There are 2 on the rear axle hinge joint.
Be aware there are 8 sealing sleeves for the hinges on the front suspension upper and lower A arms. They must be there and not broken or damaged. They are used to hold grease and protect the joint. Part number A120 333 01 30. Replacement is a pain and it would make sense to replace these if the front suspension is overhauled.
One filter and available.
One fuel filter between the pipe on the chassis and the fuel pump.
Oil filters are common among several models, get from the dealer.
Brake rotors and pars are available, rear drums are expensive.
There is a screen in the tank mounted from the bottom in the middle. It's got a hex hole and is plastic. They are still available from Mercedes. Remove the tank and get it cleaned.
Service manual CD's are available from MB. Paper ones are available on EBAY.
The W113 SL site has many good pages on service, these two cars are similar. Welcome - Mercedes Benz 230SL, 250SL, 280SL Pagoda Group. Register and use the common info in the tech manual.
I hope this helps.
wbain is offline
post #9 of 16 (permalink) Old 01-08-2013, 09:28 AM Thread Starter
Premium Member
Quoted: 14 Post(s)
Premium Member
I can rest easy...
I hope this helps.
You have answered my prayers and now I rest easy. I feel like I have learned something and appreciate the time and thought you put into the response.
post #10 of 16 (permalink) Old 01-08-2013, 09:44 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
I tried to gather all these bits and pieces in one place - see OZBENZ - Australian & New Zealand Mercedes-Benz Forums • View topic - The Finnie Bible
and OZBENZ - Australian & New Zealand Mercedes-Benz Forums • View topic - The Finnie Bible -errata
Cheers,
Drew
PS - let me know if you find anything contradictory.
drew56cus is offline
