W110 190Cmalternator Brushes - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-01-2013, 10:01 PM Thread Starter
Date registered: Feb 2011
I am sure my alternator brushes are bad. Can't seem to find a source for new brushes or a new alternator. Any advice? This is a 1963 190C.
nervedoc is offline
post #2 of 5 (permalink) Old 01-02-2013, 09:32 AM
Date registered: Apr 2008
Vehicle: 300sel
pull it out and get a rebuilt from Bosch about $95
Has your car been converted from a generator?
bwostosh is offline
post #3 of 5 (permalink) Old 01-02-2013, 12:42 PM Thread Starter
Oops!
No it is a generator I am speaking of.
nervedoc is offline
post #4 of 5 (permalink) Old 01-03-2013, 07:29 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
remove the band cover and look at brushes , there are places that recon generators , do a google .
agillot is offline
post #5 of 5 (permalink) Old 01-08-2013, 07:22 AM
wbain's Avatar
Date registered: Dec 2003
How do you know they are bad?
These cars originally came with generators. A previous owner upgraded to an alternator at some point. Check the alternator amperage rating. I suspect 35 amps.
Disconnect the battery negative lead first. Remove the alternator, and match mark the case, you can use a punch or a felt tip pen or marker. Take the case apart and the brushes are inside. The brush leads must me soldered.
To reassemble, notice a small hole in the back cover. Use a small pin to keep the brushes retracted and reassemble the case. Remove the pin after reassembly.
Brushes are available, check the EPC for a 250S/SE, 108.012, 108.014, and the brushed are displayed, look for the electrical or charging system page.
You can also upgrade to a more recent alternator with the replaceable brush - regulator which are more common. No external regulator is required.
wbain is offline
