W111 early vs late idler arm bushing ?? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-22-2012, 06:39 PM Thread Starter
Date registered: Aug 2006
Vehicle: 1972 300SEL 4.5, 1971 Citroen DS21, 1995 Jaguar XJS
Taking a shot, maybe someone has been through this already.
Apparently there are two types of fintail idler arm bushing setup. My 67 230S has a bolt attached to the arm, a grease nipple, a brass bushing and a threaded cap up top.
I have a rebuild kit for a different type, with the bolt passing through the idler arm, no grease nipple, and using rubber bushings.
Seems that W113 SL's have the brass bushing type as well.
Can I update the idler arm with the rubber bushing kit? is the arm itself different early to late setup, would i need to get a new / used idler arm from a parts car?
the brass bushing rebuild kit is $160 vs the $35 that I already paid, so if I can use what I have that would be great.
thanks in advance!
tcb323 is offline
