gravy being made by the engine breather - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-21-2012, 11:56 AM Thread Starter
Date registered: Dec 2012
Vehicle: 1978 230
I went to clean out the air cleaner and decided to take off the condensation pot that sits under where the breather attaches to the air cleaner. I found the most delicious LOOKING turkey gravy I have ever seen. I know gasses should condense in that little cup but viscous gravy? It did not smell of gas. Any one have any idea if this is normal or a bad omen?
beyeker is offline
post #2 of 5 (permalink) Old 12-21-2012, 12:08 PM Thread Starter
Vehicle: 1978 230
I should add this is the 1978 230 gasser
beyeker is offline
post #3 of 5 (permalink) Old 12-21-2012, 07:21 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 37 Post(s)
It sounds like you have a bad head gasket. Check your dipstick for the same type of "gravy".
It may be a slight leak. It's possible that you just aren't driving the car enough to evaporate the condensation in the crankcase.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #4 of 5 (permalink) Old 12-21-2012, 07:48 PM Thread Starter
Vehicle: 1978 230
Engine oil is clean. The car sat for a long time in SD ten I got it and drove directly to Idaho, 20 hours. Oil was changed before I made the trip. The connectors for the breather were terribly cracked so I replaced them when I got home. Then I was driving it daily and messing with the carb almost every night. So it was getting ventilated. I have not checked if there is more after this week.
beyeker is offline
post #5 of 5 (permalink) Old 12-22-2012, 02:08 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
It is not uncommon. It is also not uncommon for that little pot to freeze in the winter, so the engine ventilation doesn't work anymore, usually resulting in engine oil being forced out of the dipstick.
Sludge will get worse if you only do short trips.
Govert70227 is offline
