W114 Sedan rear Door removal Help Please! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-17-2012, 03:34 AM Thread Starter
Date registered: Dec 2012
does any one know the trick to removing the entire door please? i have undone the the bolts for the top and bottom hinges and disconnected the wires all easy enough but i can't get the door pin to move no matter what I try. The bottom cone shaped cover will not budge and there is not enough room to get in above it as per the photos. Any help would be greatly appreciated Thanks
Name:	Merc W114 006.jpg
ID:	485150   Click image for larger version
Name:	Merc W114 007.jpg
bignigew114 is offline
post #2 of 3 (permalink) Old 12-17-2012, 07:19 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
The pin has a lock ring at the underside, it looks like it has been painted over.
Govert70227 is offline
post #3 of 3 (permalink) Old 12-20-2012, 09:40 AM
Vehicle: 1973 Mercedes Benz 220/8
Answer for you
I have the W115 model I think still trying to find out. But to answer your question I just went through this on mine. If you live in the states mine looked like a R clip. I have to take the inside of the door apart then move the controls by hand then my door opened so I know what you are going through . Hope this helps.
blkagl is offline
