PRNDL ADJUSTMENT NEEDED 74 W115 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-08-2012, 10:29 AM Thread Starter
tedg's Avatar
Date registered: Jan 2012
Vehicle: MERCEDES BENZ 230 W115 1974
Hi All,
My gear shift steering display is out of alignment, making it hard to figure out
Neutral or Reverse. Is there a way of getting under the dash to adjust the cable....thanks in advance...Ted.
I love to learn.. I dont always like being taught.
tedg is offline
post #2 of 5 (permalink) Old 12-09-2012, 09:30 AM
NorCalSL's Avatar
Date registered: Jun 2007
Vehicle: '70 280S-'73 450SLC-'81 380SL-'84 500SEC Euro-'92 300SL24-'95 E320
Quoted: 22 Post(s)
If the W114 is like the W108, there is an adjustment on the back of the PRNDL indicator itself. You have to remove the cluster and tighten the thumbscrew.
dws
1973 Mercedes 450SLC (PineGreen/MahoganyLeather)
1981 Mercedes 380SL FORSALE (LtIvory/PalominoMBTex)
1984 Mercedes 500SEC Euro (040Black/BlackLeather)
1992 Mercedes 300SL-24 Signal Red/Black Leather
NorCalSL is offline
post #3 of 5 (permalink) Old 12-09-2012, 09:38 AM
mbkomfort's Avatar
Date registered: Jan 2008
Vehicle: -88 250D, -93 280TE-24 Sportline and -00 E270T CDI
Hi, there might be a threaded rod that can be adjusted if you can get under the car and reach the shifting arm on the transmission, there's a drawing of this in my Haynes book for W123 series cars, should be the same on yours.
But i'm not at home so i can't look it up for you, and i've only had MB's with the center/floor shifter so i'm not certain.
You should fix the problem asap to avoid transmission trouble and wear..
Set gearlever in N, set tranny shifter arm in N, adjust on the threaded rod at end of shifting cable until the connection fits together with same play in both directions.
P.s. do you have the 230.4 or 230.6 ?
mbkomfort is offline
post #4 of 5 (permalink) Old 12-09-2012, 12:16 PM Thread Starter
tedg's Avatar
I have the 230.6..thanks for your help>>:>
tedg is offline
post #5 of 5 (permalink) Old 12-09-2012, 12:17 PM Thread Starter
tedg's Avatar
thanks I will give that a try since I have to replace the bulbs in my cluster anyway...ted.
dws
tedg is offline
