280se fuel from tank to pump - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-29-2012, 06:11 PM Thread Starter
Date registered: Nov 2012
Vehicle: 1973 280se 4.5
1973 280se 4.5???
Hello ben280 here my 1973 280se is new to me. I have been haveing fule delivery problems. I dumped the gas and checked the strainer in the tank not bad at all. The fule pump and filter have less than 600mi. Put on befor I got the car. This is my ? the pump has a very small fine mesh strainer, in line it was full of very fine dusty stuff. The way they ran the fule line it goes from the tank into the pump befor the fule filter that shares the same bracket this can't be right??? I would think the fule line would go through the filter befor the pump ?? please step in and tell me what you think thankyou. Ben280 out.
benjamin280 is offline
post #2 of 3 (permalink) Old 11-29-2012, 07:01 PM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
The real fuel filter is in a canister attached to the engine mount under the injection pump. Don't confuse it with the oil filter attached to the block. It's a paper element and be careful, the canister is full of fuel. Check all fuel line rubber hoses for deterioration.
wbain is offline
post #3 of 3 (permalink) Old 12-01-2012, 05:02 AM
Date registered: Aug 2009
Quoted: 72 Post(s)
You don't filter the fuel before the pump because the fuel acts as a lubricant and heat removal system. A dry pump will overheat and seize. The strainer in the tank is sufficient to keep the large chunks out of the fuel system. The filter is to keep the injection system clean.
It's different than a mechanically operated fuel pump system where the pump is only active while the engine is turning.
Mike D is offline
