300d broken head bolt - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-26-2012, 07:18 PM Thread Starter
Date registered: Jan 2012
My timing chain broke in my 1977 300d. The cam shaft also sheared. One of the head bolts sheared while removing the head. I tried to drill the bolt and remove with an easy-out, and the the easy-out sheared inside the bolt.
Any ideas?? Can I bolt the new head on with one bolt missing? It it is an inner bolt inbetween #1 and #2 cylinders.
tstoller is offline
post #2 of 3 (permalink) Old 11-27-2012, 11:18 AM
Date registered: Jul 2012
Vehicle: 1967 250S, twin Weber carbs, automatic trans, power windows, A/C, R134a conversion
It will be extremely difficult if not impossible to remove the bolt with the sheared-off extractor still in it. These extractors are made with a very hard material that's difficult to drill through. Most drilling bits won't do it and keeping the drill centered using manual methods results in damage to the surrounding threads.
I suggest that you remove the head completely and hopefully the bolt shaft will be sticking up above the block surface. At this point a pair of vise-grips should easily remove it. If not sticking above the block you will have to weld another bolt to it and then remove it.
Shop Reminder: Chase your bolt hole threads first to clean them then install the bolt using a proper lubricant.
Kitaka is offline
post #3 of 3 (permalink) Old 11-28-2012, 08:18 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Some workshops have a spark machine that can remove a bolt.
Govert70227 is offline
