280SEL 4.5 oil pressure hose - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-25-2012, 04:37 PM Thread Starter
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 34 Post(s)
Apparently I crushed the end of the oil pressure sensor line that feeds the gauge in the dash when working on my steering box.
It broke right at the fitting that goes into the back of the head.
Does anyone have a source for this hose? All I can find is vacuum line and that won't work under engine oil pressure.
Does anyone know what the fitting on the gauge looks like. The one on the block is just barbed.
TZ_280SEL is offline
post #2 of 2 (permalink) Old 11-25-2012, 04:46 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
it is just a plastic hose that is heated and pushed on . you could in a emergengy use a piece of QUALITY gas hose of right diameter , a small hose clamp at the barb end will work safely , now at the plastic line , slip as much of hose you can , and use multi clamps . i have done it , and it work . mb makes a high quality hose that fit CIS cars at the fuel pressure accumulator at rear as a vent line for diaphragm .76 on 80 s .
agillot is offline
