Should this be connected somewhere?? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 11-22-2012, 04:24 PM Thread Starter
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
1972 250/8 There are two vacuum nipples on the diaphram that is connected to the distributor. One has a hose going into one on the zenith carbs, the other
nipple is open, with nothing connected to it. Should it be connected or at least plugged up? When I cover it with my finger, I dont seem to notice
any change when the engine is idling. Thanks guys.
Luna Gaudi's 72 250 is offline
post #2 of 7 (permalink) Old 11-22-2012, 07:46 PM
r34sklnnsn's Avatar
Date registered: Feb 2012
Vehicle: 1971 250C
That hookup is to retard the timing when you let off the throttle. It should be hooked up on the pass fender.
'71 250C "work in progress"
r34sklnnsn is offline
post #3 of 7 (permalink) Old 11-23-2012, 04:47 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
you are better of not to use the vacuum at distributor , make sure the mech advance in distributor works , set the timing at 5 to 10 deg advanced at idle , the engine will be more responsif and will run cooler .
agillot is offline
post #4 of 7 (permalink) Old 11-24-2012, 08:21 AM Thread Starter
Quoted: 17 Post(s)
Thanks for the quick response guys! Has anyone else removed the vacuums from the distributors from thier cars and what were the results? It seems to me like after I hooked up all the vacuum lines as per the diagram (thanks r34sklnns!) the car was running a lot better.
post #5 of 7 (permalink) Old 12-27-2013, 08:39 AM
Premium Member
Quoted: 59 Post(s)
Premium Member
this is the vacuum retard , this is strickly a smog issue , dont connect . set timing at 5 to 10 deg btdc accelerate to about 3500 rpm , you should have around 35 , if you do , you are done , the car will run better that way .
agillot is offline
post #6 of 7 (permalink) Old 12-27-2013, 10:44 AM Thread Starter
Quoted: 17 Post(s)
Agillot, thanks again for the info, I will try right now and report back. I am getting an intake backfire only when the engine is cold. Once warmed up and have driven about a mile, the backfire goes away.
post #7 of 7 (permalink) Old 12-27-2013, 11:37 AM Thread Starter
Quoted: 17 Post(s)
Agillot, I just want to be sure about the ADVANCE vacuum, should that one be disconnected as well?
The timing was at 15 before TDC, I adjusted the distributor to 10 degrees before TDC and it seems like
the backfire issue is no longer. Keep in mind, when I took it for a run, I did not have the advance vacuum hooked up either.
