storing a car: empty or full - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-21-2012, 01:10 PM Thread Starter
Date registered: Aug 2012
I've put my 1963 220S on blocks for the winter while I do some projects. I've heard several opinions about leaving the fuel system empty or full. My local ethanol-free gas provider said they won't get a shipment until May. Should I risk the condensation-induced corrosion or the separation and destruction of ethanol in my fuel lines?
david220s is offline
post #2 of 5 (permalink) Old 11-21-2012, 05:24 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
I thought of this when I just put my finny away for the winter. After reading a recent post on ethanol gas, I decided to leave a full tank but run the carbs dry by disconnecting my electric fuel pump until it stalled.
If you have a mechanical fuel pump, you could clamp the supply line and achieve the same result.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #3 of 5 (permalink) Old 11-21-2012, 05:24 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
Fill up your tank and add some fuel stabilizer. Take it from me - a rusted gas tank, fuel pump and lines are a bitch to sort out
Grubeguy is offline
post #4 of 5 (permalink) Old 11-21-2012, 05:34 PM
Date registered: Jul 2010
Vehicle: 05,cl65: 33 ford 3wc.
Seems like thier will be fuel in the lines (system) weather the tanks full or empty. I store my cl and antique car full of fuel for the winter with stabil, which is the convential thought, haven't had any issues. Also I never run the engine in the garage as many do as I am convinced running the engine without the load of driving adds moisture to the engine and exhaust system.
dtohio is offline
post #5 of 5 (permalink) Old 11-24-2012, 09:44 AM
Date registered: Sep 2012
I've been storing my '67 beetle for about 6 years, and I use Stabil Marine. I have not had any trouble in the spring.
audley115 is offline
