1973 280 running hot - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-17-2012, 02:18 PM Thread Starter
Date registered: Nov 2012
I have a 1973 280 that seems to run hot. Yes there is coolant but its either not flowing or maybe the theromstat or????
I have flushed the rad a while back and did a pressure check and all was good.
Any simple checks i could do? I am not a mechanic
FIREFLY571 is offline
post #2 of 3 (permalink) Old 11-17-2012, 06:49 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
Check your belts first -if your water pump isn't being turned, you won't have coolant flow.
Things that'll make you run hot: air/fuel mixture set too lean. Thermostat not opening right. Radiator plugged and in need of a flush. Crappy water pump. No air flow over the radiator (poorly operating fan)
Grubeguy is offline
post #3 of 3 (permalink) Old 11-18-2012, 03:05 AM Thread Starter
Thanks for your reply, I checked the thermostat about and month ago but will check again. I believe the pump is in working order but will have another look.
