Steering box bolt - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-11-2012, 07:53 PM Thread Starter
San Arthur's Avatar
Date registered: Jun 2007
Vehicle: 1983 300SD, 1969 280SE, 2007 C230
Steering box bolt
Lately I need to steer constantly to keep my car in a straight line.
I checked the under the hood and the steering box is moving together with the steering wheel.
I checked the bolt holding the box to the chassisi and it is moving too.
I'm planning on welding a plate to the chassis and using longer bolts.
Any suggestions or recomendations before I do this?
San Arthur is offline
post #2 of 3 (permalink) Old 11-12-2012, 07:22 AM
Check under the indercoating for stress cracking around the thru-frame-spacer and torque the three bolts. The only plate I have seen was on a 300SEL 6.3
(very heavy front)
Check all steering links/tie rods
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 11-12-2012, 09:35 AM
Date registered: Jul 2012
Vehicle: 1967 250S, twin Weber carbs, automatic trans, power windows, A/C, R134a conversion
My 1967 108 suffered the same condition with the steering bolt pulling through the frame. I repaired it by welding a metal plate to the outside of the frame (it has predrilled holes for the steering box bolts), and sealing it with frame paint. It has since worked fine for over 15 years
Kitaka is offline
