W108 3.5 Misfiring Issue - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-04-2012, 11:52 AM Thread Starter
Date registered: Nov 2012
Unhappy W108 3.5 Misfiring Issue
Hi Folks,
I have recently bought W108, 1972 3.5 V8 which was stored for few years. Have misfiring issue, rough running with black smoke with loads of unburnt fuel.
Following things have been carried out by Mechanic:
1- Compression Test (Equal Pressure in All cylinders)
2- New spark plugs, leads, rotor and distributor Cup
3- New fuel pump
4- 2 New injectors as fuel was leaking out.
5- Spark in all leads
Having taken out spark plugs after misfiring, unburnt fuel and plugs were wet with fuel.
Advice and opinion is needed and would be greatly appreciated for any ideas what could be issue as my mechanic has no idea what else could be wrong.
Regards
miw76 is offline
post #2 of 3 (permalink) Old 11-04-2012, 07:43 PM
Date registered: Sep 2012
Injectors
I would have all of the injectors rebuilt. I had mine done by Injector Rx here in Houston. They are a very nice South African couple.
Mark Aycock is offline
post #3 of 3 (permalink) Old 11-05-2012, 05:08 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Check the trigger points too.
I'm assuming you dumped the old gas and started totally fresh with new stuff?
What about points/condensor? Have you replaced or adjusted? I'd recommend dumping the wole setup and going with a Pertronix setup. MUCH better running.
Grubeguy is offline
