Oil leak or leaks in front of engine - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-12-2012, 01:37 PM Thread Starter
Syria Bari's Avatar
Date registered: Mar 2012
Vehicle: 1970 250 c
I have oil Leaking around the water pump. How many possible places could be leaking at the front of the
engine ? The engine has a lot of miles, and I expect these kind of
problems. I am just trying to keep it
going until I can afford to replace or rebuild it. Any suggestions would
more than welcome. Peace:O
Sent from my LG-LG855 using AutoGuide.Com Free App
Syria Bari is offline
post #2 of 4 (permalink) Old 10-17-2012, 04:38 AM
Date registered: Oct 2010
Vehicle: Mercedes
Quoted: 9 Post(s)
Which car? Normally is the crankshaft from seal, it´s not that difficult to change if you have the proper tools.
javimx5 is offline
post #3 of 4 (permalink) Old 10-17-2012, 05:28 PM
wbain's Avatar
Date registered: Dec 2003
Your water pump may have two bolts on the body between the pulley and the mount. These bolts are for filling, on top, and the amount, on the side.
If this is not the case, the oil leak might be coming from the front of the engine, there is a plate bolted to the top right of the block. Spray some cleaner on the area around the oil leak to determine the location. Pictures would also be helpful.
The front seal may also be suspect as mentioned before.
wbain is offline
post #4 of 4 (permalink) Old 10-20-2012, 01:03 AM
Vehicle: Mercedes
Quoted: 9 Post(s)
Do a good cleanning on the engine and look where that oil leak may be.
javimx5 is offline
