280SE 4.5 1973 Idle drop/surge - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 10-10-2012, 05:35 PM Thread Starter
Date registered: Mar 2011
I sort of posted this previously in the context of an alternator problem, but the alternator issue has been resolved and this one abides.
On starting, the engine rises to the proper idle, then idles a bit too high, then the idle drops and bottoms out, only to pick up again immediately. This continues until the engine is warm or is put into gear.
It only appears to occur when the engine is cool but not cold. Cold starts are fine, hot starts are fine but after the car been sitting for two or three hours after use, this surge (or reverse surge, I guess) returns.
Listen here (the surging begins at about 00:18):
ross220sb is offline
post #2 of 17 (permalink) Old 10-11-2012, 06:02 AM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
Typically, those problems are caused by a vacuum leak.
wbain is offline
post #3 of 17 (permalink) Old 10-11-2012, 10:55 AM
Date registered: Jan 2009
Vehicle: anywhere from '52 300 to 1990 560SEL,and a '93300TE nothing newer, too much trouble....
Quoted: 16 Post(s)
old topic
I have had this on a Euro 300SEL 3.5, but never resolved it myself, as that car was sold as is.
That car had been sitting a long time.
But I remember seeing a lengthy discussion on the subject somewhere.
Use the search function.
I'm sure You'll find something there.
Alex
6punkt3 is offline
post #4 of 17 (permalink) Old 10-11-2012, 01:08 PM
Quoted: 16 Post(s)
old topic
Alex
6punkt3 is offline
post #5 of 17 (permalink) Old 10-11-2012, 06:46 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 107 Post(s)
Wow, that's a pretty significant surge!
Grubeguy is offline
post #6 of 17 (permalink) Old 10-13-2012, 06:45 AM
Peoria Benz's Avatar
Date registered: Jul 2006
That is often the result of a sticky cold air valve. See what it is (or isn't) doing.
Peoria Benz is offline
post #7 of 17 (permalink) Old 10-13-2012, 09:14 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
The cars of this era seem to run on vacuum as much as fuel. If there are any vacuum leaks, you will have all sorts of weird problems. That being said, checking the function of the AAV, Slide Valve, cold idle valve (actually just different names for the same valve) would be a good place to start. It can even be removed and cleaned with carbueretor cleaner.
RadioTek is offline
post #8 of 17 (permalink) Old 10-17-2012, 03:36 AM
Date registered: Oct 2010
Vehicle: Mercedes
Quoted: 9 Post(s)
Ok, itīs an easy one, itīs the cold air valve. This is how it works. The fuel system detects an increase of air going trough the system and sends more fuel but then detects that the throttle valve is not being actuated so it cuts the fuel being sent. this happens at aprox 2.000rpm
When the engine is surging down the system detects that the engine is going to stop so at about 750rpm sends a signal to the system to inject fuel.
The surge is between 750 and 2.000rpm. Thatīs beacuse the cold air start valve remains open. This valve actuates mechanically, itīs like a thermostat, remove it and cleanned internally, how to do it?
Remove the valve, on top of the engine, in front, it has 2 air hoses.
Boil water and introduce the valve, when hot (around 2 minutes in boiling water) the valve will close (in this case open). Pour inside a good degreaser, or even WD40, take the valve out and deep it in iced cold water. Repeat this 8-10 times.
How to know if it is fixed? After finishing the procedure and with the valve hot try to blow up air inside one of the wholes, no air should come on the other end.
javimx5 is offline
post #9 of 17 (permalink) Old 10-18-2012, 06:57 PM
That is what I was talking about, but a much better description. I have not had great luck getting these valves to return to their proper behavior, but his ideas all seem reasonable. Might try them myself in the future. If you try them, please post your results. Happy motoring!
post #10 of 17 (permalink) Old 10-18-2012, 11:16 PM
Vehicle: Mercedes
Quoted: 9 Post(s)
The way the valve works is quite simple, the bronze capsule is filled with a kind of wax that expands when heated, this forces a pin to rise and close the valve.
At time passes by the pin gets all kind of dirt, normally is oil fume mixed with dust that burnts out and gets stuck on the pin walls so it doesnīt move anymore.
An used valve will cost you around 100-150$.
How I do it.
1- First, I deep the valve in a special carburetor cleanner for about 24hrs, that getīs rid of all dirt stucked inside.
2.- Then I use the procedure I explainned before, hot-cold water.
I did this last time a month ago on a 350SL, same problem as yours, now works perfectly.
javimx5 is offline
