breaks squeaking on '74 240d - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-30-2012, 12:44 PM Thread Starter
Date registered: May 2012
My brakes on my car are squeaking when I press on the brake pedal, and the car stops quickly. Usually, when the brakes squeak, it means I need new brake pads, however, before I do that, I want to make sure this is the case for a car this old. Could it be something else? What can I check to see what is causing the squeak? Perhaps this is common for a car this old?
ifthecar is offline
post #2 of 3 (permalink) Old 09-30-2012, 02:09 PM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
Take the wheels off and inspect the brakes. The pads need to be at least 1/4" thick and if not, replace them. There are thin shims between the pistons and the metal backing plate and there needs to be anti-squeal paste on the base plate. Yours may not have the thin shims, so check with your dealer or the EPC brake page for your car. You may be missing some parts.
You might need to replace the brake disks as well, if they are too thin.
wbain is offline
post #3 of 3 (permalink) Old 10-01-2012, 01:04 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
And if you replace the brake pads, buy ones with a groove in the middle.
Govert70227 is offline
